Old 09-13-2005, 01:54 PM   #1
navybear70
hometown heroes!
navybear70's Avatar
PICS of some bad stuff under bed.
To those who have been helping me out, this thread makes sense. ...and thank you.
Wow, those are crappy pictures. My daughter's camera...
Are those the correct Ubolt sizes? They seem kinda thin to me. The rust is really worse than the pictures show. Am I crazy, or does the frame look slightly bend(buckled down) at the mount?
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th...
Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee
"Never give up ground you've already taken." -Unknown
navybear70 is offline   Reply With Quote
Old 09-13-2005, 09:54 PM   #2
masterbeavis
Having issues
masterbeavis's Avatar
Too bad you dont have any west coast connections..... there are tons of these frames gettin crushed weekly at junkyards....
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-13-2005, 10:23 PM   #3
71SWBChevy
Post Whore
71SWBChevy's Avatar
If you need a new frame and that is a SWB truck I may have a frame for you in about a month if you would be interested. The frame is in Owensboro KY which may be farther than you would be willing to go for a frame, but I will make sure I post once I pull all the parts I need off of it.
71SWBChevy is offline   Reply With Quote
Old 09-13-2005, 11:08 PM   #4
shortymac83
hmm...
shortymac83's Avatar
that U bolt looks like the ones that came off the 69 rear I'm sticking in my truck...
and what's wrong with that frame? looks pretty solid to me...
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 09-13-2005, 11:52 PM   #5
71SWBChevy
Post Whore
71SWBChevy's Avatar
He said something about it being bent, I think that was the main problem. Also he said the rust was worse than it looks.
Old 09-14-2005, 02:32 AM   #6
navybear70
hometown heroes!
navybear70's Avatar
Yes. I'll be looking over a 69 stepside tonight(possible donor). I'll check the frame angles there. The rust on my truck is quite complete on the inside of the pass. spring mount. The frame is rusted to nothing right along with it. A PO attached the coil spring bolt to a broken off piece of leaf spring with a hole drilled in it! Didn't even weld the piece in!
