Glovebox woodgrain
How do you attach the woodgrain pannel to the glovebox door? 2 sided tape?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
72 Cheyenne
That or some kind of glue, I would use the tape just in case you needed to take it off for some reason. I used the tape and it looks fine.
Keepin' It Stock
I used a 3M clear double-side tape for mine. The stuff is about 1/6" thick, crystal clear, and rubber-like (not foam). It is veeery sticky and has held very well. I got it at KMart.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
| Bookmarks |
