Old 09-14-2005, 11:58 AM   #1
orvillespooner
Fender decal/pinstripe source? '86 Subrbn
Where can a fender decal for an '86 suburban be purchased?
Two tone paint, separated by the stripe.
orvillespooner is offline   Reply With Quote
Old 09-16-2005, 01:50 PM   #2
jflots
I couldn't find a source when I had mine painted 3 years ago. GM doesn't make them anymore. Paint suppliers have some striping that you could find a close color match...maybe. I ended up using boat striping used on Boston Whalers. It's a 3/4" dark blue strip with a 1/8" pinstripe under it with a 1/8" space inbetween. It actually looks much nicer than original. My '86 is 2-tone blue. Good luck.
jflots is offline   Reply With Quote
Old 10-08-2005, 08:24 AM   #3
WLPTMP
Active Member
WLPTMP's Avatar
a company called vpi buys all of GM's obsolete stuff now so let me know what u need i'll get a part number and call them monday from work to see if they have it
WLPTMP is offline   Reply With Quote
Old 10-08-2005, 10:21 PM   #4
orvillespooner
Thank you
However I gave up and over the past three days I painted the stripe on the fender. I wasn't easy but it looks almost perfect. From 10 ft you can't tell. The base stripe was brown and the pinstripes over the top are tan. Also the stripe tapers to the front and the pinstripes also taper. And the whole thing is forms a curve! Using careful measurements it is very possible to succesfully do it!
Old 10-09-2005, 08:52 AM   #5
WLPTMP
Active Member
WLPTMP's Avatar
sweet
