04-14-2002, 07:07 PM | #1 |
Wheels
If I want to put a srt of 20 inch wheels on my 71 C10 how wide can I go? What does it mean by back spacing.
1970 k10 1971 C10 Gilbert Az |
04-14-2002, 07:47 PM | #2 |
Backspacing is the distance from the mounting pad or surface to the inner most edge of the wheel. MiniTruckin has a good article in the current issue about measuring backspacing and should really help in determining the right size. Something else to keep in mind is how much drop you have. The more drop you have the more critical the measurments become. Hope this helps
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
04-15-2002, 10:58 AM | #3 |
If your looking to run 20's all around, then 20x8's in front w/5.25 b.spacing. In the rear anything wider than 8's usually means 9.5" minimum. Although a 9.5" wheel will fit the b.spacing will vary according to ride height. On my 67 I have 20x10's w/6" of backspacing. From the front, the wheel has the same spacing as a stock truck ralley & I widened my wheeltubs to accomodate the offset. FYI: this set-up worked great when i swapped it on to my 68 beater(5/7 drop) but on my 67(approx 8/10 drop)the rear b.spacing would work better @ 6.5" because the truck sits so low that the tires are actually rubbing the inside bed wall & I didn't consider this as I was mostly worried about the wheeltubs clearing. Live-n-learn.
04-15-2002, 11:54 AM | #4 |
Got 20's????
I have 5.5 backspace on my 17's and you would not want to go any wider. Its about 1/2 inch from the inner wheel well (in back)
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
