Old 09-14-2005, 09:19 PM   #1
rmoorhead
rmoorhead's Avatar
Help
Its time toget rid of the old long tail three speed that came with my 62 c10.
I am looking for a four speed that will let me keep my hydro clutch set up.
Any suggestions?
rmoorhead is offline   Reply With Quote
Old 09-14-2005, 09:21 PM   #2
zenish
you can use a t5 five speed from an s10.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 09-14-2005, 09:34 PM   #3
rmoorhead
rmoorhead's Avatar
That was quick! Does this take alot of mods? Can I keep the rear end or do I get one from an s10
Old 09-15-2005, 01:25 AM   #4
speedking
You should be able to keep your rear end,depending on the ratio;the S-10 will have a slight overdrive 5th gear. Also keep in mind you'll have to have your driveline modified to fit(different length and different yoke),and you'll have to use a clutch disc that fits the S-10 input shaft splines and has the right diameter. (I believe you have to trim the end of the input shaft slightly and change to a different pilot bushing,but I could be mistaken on that.) Depending on what seat you use,you also might have shifter clearance issues.If you're already running freeway gears,you could use a 4 speed;I have a saginaw 4 speed(like they used in the mid 60's Impala etc.) I'm planning to sell. It's nearly a bolt in,but won't have the overdrive and you'd still have to modify your driveline to the correct length and get a shifter. BTW-the Saginaw uses the same yoke as a T-350.
Speed
-57 GMC 1/2 ton longbed,Pont. 400,4 speed
-62 Chevy 1 ton duallie,Chevy 355,4 speed
-66 Pontiac Catalina 2 dr. hardtop,389,T-400
-81 Ford Fairmont wgn.,2.3,4 speed
-68 Triumph TR6-R 'cycle,various mods
-66 C-60's back
-there's probably others...
speedking is offline   Reply With Quote
