72 5 bolt lug patteren????
what is the spacing for the 5 bolt lug patteren?????
5" bolt circle
i know that what is the measurement from center of lug to center of lug im trying to buy a set of wheels
![]() Join Date: Jun 2002
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 07-31-2016 at 07:44 PM. Reason: Link didn't work, Rg |
#5 | |
Best of Luck. |
Just ask for 5x5 or 5 on 5 and you will be set.
"You can take the man out of PA, but you can't take PA out of the man" |
thanks for to help guys
nate |
center to center is 5"
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
The 5 inch dimension is the diamter of the bolt circle. On a 5 lug, the lugs are not straight across from each other. The measurement from center to center will actually be somewhat smaller than 5 inches technically. On a 6 lug or a 4 lug, you can measure from stud to stud though.
