72 Cheyenne
What is this part called?
The rubber gasket that fits inside the brace holding the shaft, the rubber is bad, the shaft moves around when I change gears? What's it called, Port shaft gasket? The white stuff is grease.
its called old and worn out, just like me......LOL!
OK really, It's a carrier bearing.
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
![]() Join Date: Sep 2001
Center Support Bearing. You need a new one.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
Type 1 drive shaft bearing. About $20-30, depending on where you buy it.
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
72 Cheyenne
Thanks guys, I'll call Napa.
In Classic Truckin last year (or so) there was a new products that showed a manufacturer that made a carrier bearing that used polyeurethane for the insulator. Can't remember the company name but I think they were out of Canada.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
