Old 09-15-2005, 01:10 PM   #1
fastbagged68
fastbagged68's Avatar
Help I need part #'s for shocks
I need part numbers for shocks on 69 fleet lowered 5" front and 6" rear. Front has 2.5" drop spindles and 2.5"springs, Rear is 4"spring 2 inch block. I need to go to my local parts store and get them. Our parts store guys are not the brightest, so I need the part #'s. Any Help!
fastbagged68 is offline   Reply With Quote
Old 09-15-2005, 08:04 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Your going to have to do some research, measure the ride height from shock bolt to shock bolt. Add 2.5 -3 inches to that and subtract 2.5 - 3 inches from the same number so you have the minimum and maximum travel as well as the center range. Go over to http://www.monroe.com/catalog_lookup...iscappinfo.asp and match up the dimensions and the mountings.
dwcsr is offline   Reply With Quote
