Timing cover oil leak question
My timing cover is leaking oil at the bottom. Is there supposed to be oil behind the timing cover and what would be the sources, or most common source for a leak? Like, is there a crank seal that fails or what? Or is the oil just woriking it's way from the oil pan? I noticed before the problem began, a high pitched noise from the front of the truck had developed. You could hear the noise around 60 mph and above, but it would stop if I dropped down below 60. I'm trying to figure out how much to take apart to diagnose and fix it and also to decide if it can be done in an apartment parking lot. Thanks very much for any comments.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
I had the same problem on my 350 . i replaced the oil pan gasket with a 1 piece and never had to worry about it again
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
It's a catastrophic success.
![]() Join Date: Jan 2003
Clean around it real good, and then look closely for the leak,if its leaking around the crank shaft, pull the harmonic balancer and replace seal.if its leaking lower then you will have to pull the oil pan to replace the gasket.
Cantankerous Geezer
Also, if it's the oil seal leaking, there is usually a groove in the shaft of the balancer. This is easily fixed with a redi-sleeve, slides over the shaft.
I'm concerned about the noise, though. Does it occur when the engine is at speed?
Fred There is no such thing as too much cam...just not enough engine. ![]() |
There is no noise when the engine is idling or at low speeds, just when I get on the highway and start getting above 55 mph. I will replace the oil pan gasket with a 1 piece and also install a new timing cover gasket and go from there.
#6 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
~Rest In Peace~
this would be a good time to replace the timming cover with a two pc timming cover
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Problem fixed! I replaced my oil pan gasket with the 1 piece blue gasket from Fel-Pro and so far so good, no oil leak! Gasket # 0S 34509T, fits '57-'74. Thanks very much for all the help!
I have had the front seal leak bad after 30 miles on fresh machine shop rebuild,changed the front crank seal,same thing...when them align bore a block...it moves the crankshaft up into the block deeper...Is there i fix for this? Anyone ever have this problem?
Cantankerous Geezer
Bisquik - Are you using an old balancer? If so, did you put a redi-sleeve on it? Any grooves in the balancer will cause leaks.
If it's a new balancer, then you need to center the timing cover on the crankshaft. What I can't recall is if there are alignment pins for the cover. If there are, they need to be taken out of action, easiest way is to open up the holes so the cover can move up. Pull the balancer and cover and clean things up. Put a new seal in and glue the gasket to the cover and let it dry. I prefer a non-hardening sealer, such as the aviation sealer. Apply a thin coat to the back side of the gasket and the block. Put the cover on with two bolts that are loose. Then put the balancer on far enough to engage the seal, allowing the cover to move in alignment. Snug down the bolts and put in the rest of the bolts. You might have to pull the balancer off to install the bolts, depends on the application. Should solve your problem.
67-72 Addict!
skillet- I just saw on advance auto parts site the part number changes in 1975. What's the difference in pans?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 09-30-2005 at 08:02 AM. |
I'm not sure the difference in pans, but the number does change.
0S 34509T -- Chevrolet small-block V-8 '57-'74 OS 34510T -- Chevrolet small-block V-8 '75-85 Os 30061T -- Chevrolet big-block V-8 '65-90
#13 | |
I never wold have thought of doing that,Thanks.....Erick
#14 |
Egad! My leak reared it's ugly head again today. So now I am repalcing the timing cover gasket and seal. The Fel-Pro gasket set I bought includes everything you need, timing cover gasket, harmonic balancer seal and a repair sleeve.
