Old 09-15-2005, 04:50 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Angry Blazer tank problem. Please Help
Okay I am trying to install the tank, going in from the bottom. Well the filler neck is hitting the frame rail, leaving no room to attach a hose. I can't even get the tank straps on the other side to reach the bolts.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-15-2005, 04:52 PM   #2
cableguy0
if that frame was so nice and shiny i would say it was time to get out the bfh and dimple it. maybe if you cut the neck down about an inch you would gain the room you need to put the hose on
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-15-2005, 05:33 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
A couple of thoughts I had was to cut a notch in the frame, or have the filler neck bent a little at a muffler shop.
Old 09-15-2005, 05:38 PM   #4
cableguy0
personally would notch the frame at least not very much. i would modify the filler neck itself. i bet you can get one with a curve in it that will clear the frame.
Old 09-15-2005, 05:41 PM   #5
68 short step
yea that would wook for awhile, until the frame rubed a hole in the rubber gas hose(not good). can you send pics of you looking up at the tank (what is stopping the tank from goind up any further).i think youl'll either have to mod the way it sits ( lower the point that the tank hit the frame) or notch that awsome lookin frame. good luck. keep us posted as i am gonna be going through this soon too.
68 short step is offline   Reply With Quote
Old 09-15-2005, 05:44 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Cut the neck shorter and get a longer hose, just a thought
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-15-2005, 06:07 PM   #7
jugernot
Life, Be In It.....
jugernot's Avatar
Well I messed around with it some more and was able to get both straps attached. The filler neck is a little higher but not much.
Old 09-15-2005, 06:21 PM   #8
matthufham
now try to put the bed on, the filler neck goes right where 1 bed mounting bolt goes.
matthufham is offline   Reply With Quote
Old 09-15-2005, 06:48 PM   #9
guyryan100
guyryan100's Avatar
I have that same problem when it comes to the frame mount. I've resolved just to leave it out and keep weight in the front of the bed. I think.
guyryan100 is offline   Reply With Quote
Old 09-15-2005, 07:10 PM   #10
72MARIO
72MARIO's Avatar
You beat me to that comment.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-15-2005, 11:09 PM   #11
72CSTC5
72CSTC5's Avatar
I guess stupid question but is the tank for 67-72 applications? Is it the original tank for the vehicle? Aftermarket maybe? Just a couple of thoughts I had. I wonder if my poly tank is the same way that I bought for my Blazer.
72CSTC5 is offline   Reply With Quote
Old 09-15-2005, 11:12 PM   #12
jugernot
Life, Be In It.....
jugernot's Avatar
It is from Truck Shop and is thee blazer conversion kit for 67-72 trucks.
Old 09-15-2005, 11:23 PM   #13
72CSTC5
72CSTC5's Avatar
You know my 2wd blazer frame spreads out a little in the rear from regular 2wd truck frames. I wonder if that could be your problem. If the tank is for a blazer and the blazer frame is wider in the rear. If you look at a 2wd blazer frame from the top it spreads a littel before it goes to the rear. I havent looked at a truck frame in a while to remember. It seems to me that is the problem when Blazer guys try to use truck frames to convert 4x4's. Just a thought. Could have the neck cut and rewelded at a gas tank repair shop.
Old 09-15-2005, 11:24 PM   #14
72CSTC5
72CSTC5's Avatar
You know looking at it again, I would get my floor jack handle and insert it in to the neck (if it fits) and bend it up just a little so that you can fit a hose on it and it will not rub.
Old 09-16-2005, 01:21 AM   #15
Deuce
Deuce's Avatar
Drill 4 new holes and move the tank back and the filler neck will clear the mounting bolt, but the tank will still hit the cross sill.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 09-16-2005, 07:53 AM   #16
jcfoote60
Active Member
jcfoote60's Avatar
I feel your pain, just went through that a couple months ago. I bent the filler neck up just a bit, had to cut my cross sill up 2 inches (bed was on so that was lots of fun) and then moved the tank rearward as much as possible. The other thing was that I originally bought 1-3/8" standard fill hose...didn't work because it kinked at the tank because of that angle you have there. Instead I was able to get 1-3/8" filler hose that was reinfored with wire, the wire is imbedded within the hose material...pretty cool stuff and easy to work with. Now it doesn't kink. My setup has worked pretty well. Good luck!
jcfoote60 is offline   Reply With Quote
Old 09-16-2005, 10:01 AM   #17
kaycee
kaycee's Avatar
Just remove the cross sill plate alltogether,my tank fit like a glove but I did remove croos plat the only problem I had was finding the reducer for the hose to filler spout.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 09-16-2005, 11:07 AM   #18
purple gas
I used a van as a donor vehicle and saved the gas tank & hoses in case I can make it fit. The filler hose pieces on the van filler parts are flattend about 50% in one spot spot. Just something you might consider.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
