09-15-2005, 06:40 PM | #1 |
TPI Intake Complete $200 plus s/h
As title says, I am parting a 1985 Trans Am with TPI. TPI is complete with Intake, Plenum, Runners, Fuel Rail, Fuel Injectors, Throttle Body, Distributor and anything else intake related. Asking $200 plus S/H which should be between $35.00 and $50.00 depending on where you live. It is missing the distributor cover which can be found on Ebay. Get the one for the vette, they are aluminum verses the plastic ones found on the camaros.
Engine is shot, has rod knocking but other than that the TPI runs fine. Also selling the accessories and brackets from it(not serpentine) and 700R4 Trans.
2011 Camaro 1SS LS3/6 Speed |
09-15-2005, 06:43 PM | #2 |
Does that include the computer and wiring harness too?
Is it a 305 or 350?
71 Factory SWB 4x4 Project 383/350/205 69 LWB 2wd CST Daily Driver ZZ4/700r4/3.73 72 SWB Future Hot Rod Last edited by Litdave; 09-15-2005 at 06:44 PM. |
09-15-2005, 06:54 PM | #3 | |
I could throw in the harness and computer for an additional $25.00. ($25.00 for computer and harness is free, its an 85 so i'm sure there are some spliced wires somewhere in it)
09-15-2005, 07:04 PM | #4 |
I'm interested in this. What blocks will it fit on without modification?
Is it mass air or speed density?
69 GMC 3/4 ton LWB 383 TH400 Dana 60 '84 300ZX '79 Nova (for sale) Last edited by aitch; 09-15-2005 at 07:06 PM. Reason: adding question |
09-15-2005, 07:15 PM | #5 | |
It is a Mass Air system but can be converted to Speed Density if you want to due away with the MAF. Maf sytems due better with cams and larger Cubic Inch Engines without custom Proms..........jt I dont have the MAF for the TPI system. Got a good deal in a trade for C5 corvette Brake brackets for my Camaro. Sorry
2011 Camaro 1SS LS3/6 Speed Last edited by jtmiller92; 09-15-2005 at 10:45 PM. |
09-15-2005, 07:35 PM | #6 |
Vintage Evil
I'm interested. What will s/h be to 68505? how many miles are on it? Might also be interested in the trans. Is the mileage the same on it?
Let me know Thanks
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
09-15-2005, 07:46 PM | #7 |
Mileage on the car is 139k, Not sure if the trans has ever been rebuilt but it pulls fine with engine knocking and all. Shipping would be crazy on the trans though. Shipping would be $35.00 to you.
09-15-2005, 07:53 PM | #8 |
I am interested as well. Shipping to 85242...Just putting myself in line...
09-15-2005, 08:07 PM | #9 | |
09-15-2005, 08:15 PM | #10 |
I imagine I would need an O2 sensor, fuel return line, and fuel pump to make this work, correct??? Missing anything?? Wouldn't an aftermarket wire harness be needed?? In '85, did they use a 9th injector, will this work good with a CompCams 268 grind camshaft?? I know it is alot of questions, but, well you know...
09-15-2005, 09:51 PM | #11 | |
Yes, you will need an O2 Sensor, you can just weld on o2 Bung to your existing exhaust. Cant anwser the return line but even if you did it would be low pressure. Yes you will need a fuel pump either an in tank which may be difficult in your case or an inline that puts out 45-50 psi. ban aftermarket harness isnt completely necessary you can splice into the stock harness but the aftermarket would make it alot easier. 85's did have the 9th Injector also know as the cold start injector. I will anwser what I can but you may want to look at www.thirdgen.org in the TPI section for better technical advice. The 268 Cam isnt bad, i believe the Maf would have no problems with it. You may want to get the 22lb or even 24lb injectors though..............jt
09-15-2005, 10:38 PM | #12 |
computer illiterate
pm sent
72 2wd blazer 72 swb 4x4 |
