Old 09-15-2005, 09:54 PM   #1
bud45
Shifter "flop"
Still have the "three on the tree" shifter & wanna keep it- problem is, it flops about two inches lower than I like it & is still sloppy, even after I shimmed it with the nylon washers I mentioned before from the Peterbilt dealership. Is there any other way to adjust the shifter UP to get off of my right knee? Thanks, Bud
bud45 is offline   Reply With Quote
Old 09-15-2005, 10:02 PM   #2
lowrider79
Heat up the shift lever and bend it
lowrider79 is offline   Reply With Quote
Old 09-15-2005, 10:19 PM   #3
kingsolver72
10/30/19
kingsolver72's Avatar
That sounds pretty low.You must have some long legs.Can you rotate the steering column counter clockwise a bit?
kingsolver72 is offline   Reply With Quote
Old 09-25-2005, 12:25 AM   #4
bud45
I'll check on the ccw rotation bit...unless it makes my steering wheel off-center? Don't want to heat anything up with a torch- it'll mess up the chrome!
Old 09-25-2005, 01:00 AM   #5
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
The shifter in my 67 was insanely floppy. It ended up being the bushings for where the levers on the side of the transmission meet the rods comming off the column. I ordered up gm pn# 3975132 times 4 & it is wayyy better now. Just my 2 cents.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
