Old 09-15-2005, 10:30 PM   #1
screwballl
Tonawanda 454
screwballl's Avatar
Factory 12V radiator fan?
My 91 has an electric fan on the front side of the radiator and even on the hottest and most humid days here I have never seen/heard that fan come on. Even when sitting at the bank drive thru and the temp gauge is sitting around 190-200 instead of the usual 150-160. There is a wiring harness but because it goes into a split loom with 4-6 other wires it is impossible to trace it without tearing apart the grill and everything else along the way. Is it hooked to a switch that determines when the engine is under more stress than usual and then turns it on?? I know it does work because I unhooked the harness and hooked the battery directly to it and it works fine.
Does anyone have a wiring diagram for a 91 R2500 burb (with 454 since other 91s with 350 dont seem to have them)?
If it is hooked to a switch that isn't working, either I can replace the bad OEM switch or I wonder if I can use an existing unused toggle switch inside the cab to turn it on when needed without causing error codes.
Also if possible does someone have a vacuum diagram as well, I am looking to replace the vacuum lines to be on the safe side but just in case I mess them up.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 09-15-2005, 10:45 PM   #2
79Silv4x4
Workaholic
79Silv4x4's Avatar
Nope, but Oreilly auto lists a temp sensor, fan switch and relay--maybe you could take a look at their parts and spot it underhood.
79Silv4x4 is offline   Reply With Quote
Old 09-16-2005, 12:27 PM   #3
toroflow
I have one of those on my 88 crewcab dually 4x4....the fan only kicks on when the temperature gauge is past the half way mark....so that means at about 220 degrees....yours is probably fine, but I would sure like them to come on sooner!!
Ken
'60 GMC 3/4T 4x4
'60 GMC Suburban 4x4
'64 GMC Suburban 4x4
toroflow is offline   Reply With Quote
Old 09-16-2005, 01:13 PM   #4
cableguy0
temp at 190-200 is exactly where it should be
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-16-2005, 10:04 PM   #5
screwballl
Tonawanda 454
screwballl's Avatar
mine usually runs about 150-160 normally... I start to worry when it gets around the 200 mark... wow 220? that would mean almost a meltdown and melting the tabs off a good block...
Old 09-18-2005, 01:19 AM   #6
Josh
He's got mean nasty FANGS!
Josh's Avatar
The TBI trucks are designed to run at 180-200 for fuel mileage and emissions, runnign them colder will just hurt MPG and performance... newer gen III stuff runs at 210 degrees all day, it wont hurt a thing to run at that temp...
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 09-18-2005, 11:52 AM   #7
screwballl
Tonawanda 454
screwballl's Avatar
so I am guessing that mine is probably running with a 160ยบ thermostat? hard to tell since I just bought it a few months ago
Old 09-24-2005, 06:13 PM   #8
screwballl
Tonawanda 454
screwballl's Avatar
looking through the LMC parts catalog that i got in the mail a few days ago the only electric secondary fan switch they have listed is for an 86 3/4 ton... no other years and not for 1/2 ton... so my search continues.
I guess my main thing is I would liek to cut the power wire and have it hooked to a switch inside, but I don't know if it would send back an error message and turn the "dummy you have something wrong" light on.
