![]() Join Date: Jan 2005
Original Exhaust Routing '69 K5
Hey y'all,
I realized that the goober that installed the last exhaust on my K5 made it impossible for me to install the missing front driveshaft until I replace the exhaust. (not to mention it has mufflers with blown baffles and leaks everywhere). It goes from the factory-looking downpipes into some offset pipes, under the front floorboards on either side is a muffler and the exhausts side exit in front of the rear tires. The passenger side downpipe is right in the way of the pinion yoke on the front axle. What I want to do is have the exhaust redone at a shop similar to the original routing. I see some old hanger remnants under the frame, it looks like it might have been a single exit on the drivers rear? Where do they do the crossover, and where do they hang the muffler? Anyone have any good pictures of the chassis that show the exhaust?
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Here is an idea for a single exhuat that will
give more HP than dual exhaust. http://www.castheads.com/2into1_systems.php ![]()
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
SKINNY TIRES RULE!
Not sure if this helps but I dig the routing of the exhaust on my '72. The tail pipes are tucked up so you can't see them. The work was done when I bought it, so I don't know who did it.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#4 | |
The LuvShack Garage
About 20 pic's of mine in my sig, pages 13-15 I think, but not positive ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Re: Original Exhaust Routing '69 K5
All right, dragging this back up to the top.
Shops are quoting me over $400 to do the work. While that is not bad, it is more than I wanted to spend on that part of the truck right now. Is there a pre-built system for the pickups that can be easily modified to save me a bit of cash? I am thinking that the pickup routing is very different due to the rear-mounted gas tank on the Blazer, but I'd love to know one way or the other. Anyone?
![]() Join Date: Dec 2002
LMC sells one for less than $200 bucks. Can get straight out the back or out the side. My 71 has been on for 8yrs the 70 for 3 yrs. Make sure you lay it all out and test fit before you start cutting. Kit fits long bed then you cut one pipe on each side for fit shortbed/blazer etc. Pipes are not marked very well especially tailpipe. For the money IMO can't touch it. Has good sound
#7 | ||
The LuvShack Garage
Although I can't stand LMC, except for their bathroom picture book, I agree with Pound, dollar for dollar this is the cheapest thing out ![]() Quote:
for Duals, high quality mufflers, tailpipes, tips, total w/ tax, etc......
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 11-12-2005 at 08:26 AM. |
#8 | |
Thanks for the tip guys, I had looked at that LMC system before but since it said you could cut down to fit shortbeds and not Blazers I was questioning whether it would fit. I agree that LMC is probably not the best but if it is really that easy (and saves me more than half) it is the best route for me right now. Y'all are so helpful, I appreciate it!
Dragging this WAY UP to the top.
I finally ordered the LMC system last Saturday, completed 90% of the installation today. I had to trim both of the side-exit pipes and one each of the horizontal runner pipes. It is 100% Made in USA, I love that! Mandrel-bent, all clamps, gaskets, and hangers needed to install. Very pleased with the value of this system. I can't comment on the sound until after I get shorter exhaust studs for the manifold on the passenger side. Apparently you have to remove the heat-riser at the bottom of the manifold for everything to line up. I will update with more comments and pics tomorrow (well I guess later today LOL).
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... Last edited by 69TowRig; 12-10-2006 at 03:11 AM. |
The LuvShack Garage
The LuvShack Garage
Looks pretty good
