Wanted Emergency Brake for SM465
I need the emergency drum brake and all the parts to bolt on the back of a SM465, if they exist. Next option would be backing plates for emergency brake cables on a Eaton HO52 or HO72. Any help would be appreciated.
Larry |
The only trannies that used that kind of setup were the c40-c90 series trucks. You'd have to have the lever for it that mounts to the right of the shifter.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
There are actually two types, internal and external. I've got the lever. Do you have the rest?
Larry Last edited by Lgriffin; 09-16-2005 at 05:57 PM. |
#4 | |
User #12137
![]() Join Date: Apr 2004
heres a pic of it ![]() |
That's what I need. That's the internal type. I don't see a lever off the side shift lever for it. I'm assuming it has a lever under the dash? I'll pull the parts off my 465 that it will be replacing and send them to you so you will still have a good 465. I'm not sure what that is going to do to the drive shift lenght. It's going replace a 420. Any way send me a PM and we will work things out.
Thanks, Larry |
i've seen a tranny at the junkyard that has one of those on it, i'll check if it's still there and if it's what you need. i didn't know they had those on 1 tons, i thought it was just the big rigs.
#7 | |
User #12137
User #12137
heres the pic of the cable
![]() if your wanting this pm me please |
