Old 09-16-2005, 06:06 PM   #1
bigbluthng
bigbluthng's Avatar
5 lug wheels
can anyone tell me if 73-87 rallies will fit on a 72 2wd blazer without rubbing.
bigbluthng is offline   Reply With Quote
Old 09-16-2005, 06:29 PM   #2
Scrubby
Check out GMTrucks.org
Yes.
Scrubby is offline   Reply With Quote
Old 09-16-2005, 07:21 PM   #3
bigbluthng
bigbluthng's Avatar
thanks
Old 09-16-2005, 08:47 PM   #4
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
unless you got dropped spindles.
milehightoyz is offline   Reply With Quote
Old 09-17-2005, 01:01 AM   #5
bigbluthng
bigbluthng's Avatar
no dropped spindles for now, just bags all around. i will eventually get 20's but i want to roll with the rallies while i work out the bugs and do the bodywork.
Old 09-17-2005, 10:16 PM   #6
a squarecan
How come you cant run rally on drop spindles? I just picked some drop spindles up and need to get some rims, I was going to pick up some cheap ralleys but if they are not going to fit I may need to re-think my options.
Keith
a squarecan is offline   Reply With Quote
Old 09-18-2005, 10:06 PM   #7
raggedjim
raggedjim's Avatar
Keith, the 15" wheel will hit the A-arm if you use drop spindles. I think you can grind the arms some and get away with it, but I'm not sure.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 09-19-2005, 01:16 PM   #8
71swb4x4
71swb4x4's Avatar
I have the 73-87 rallies and 2.5" drop spindles. It was this way when I bought it, so maybe the A-arm has been ground down.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
