AttentionDeficitDisorder
1978 Blazer 4wd to 2wd progress w/pics
Made some progress in the last few days. She starting to look a little different:
![]() As of four days ago: As of today: Last edited by milehightoyz; 09-16-2005 at 08:56 PM. |
It followed me home?
DAMN!!! thats low
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#3 | |
yeller
![]() Quote:
Looks good! ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#4 | |
needin' money
MY EX DRIVES A BROOM
how did you get yours done so quick?......i just hit the point of engine installation......you did the frame swap didn't you.......good job.... i am slowly getting closer with mine
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
thats gotta be bagged-with no front inner fenders
1987 350 TBI lowered 5/7 |
yeah i did swap the entire frame out. that wasnt a whole lot of fun.
Actually no air yet, this is a static drop, prolly not the best riding drop ever, but static nonetheless. 3" spindles in front, 1 coil whacked off, 3.5" z, flipped in the rear, 2" shackles, 2 leafs taken out. this is all temp set up, waiting on air and 4 link parts to come in. still need to finish fabbing trans mount. but frame is almost laid. thought this was a cool shot of it slammed and the old 4x4 frame in the background. ![]() |
#8 | |
Go Fast - Be Loud |
needin' money
what is your turning radius then
i dont know yet, i dont have my steeing column hooked up. just by eyeballing, my guess i would be about 1.5" each way.
#11 | |
needin' money
i see, im not quite sure. im gonna have to get back to you on that one. i really have no idea.
#13 |
Until Seventy Times Seven
Boy, you don't take long.
It looks good. ![]() Got any close-up and backside pics of the Z'ed portion of the frame.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#14 |
whats up boxrodz,
heres a couple of how I did the z: |
#15 |
Insert Witty Text Here
Well, I can see why you removed the running boards...
![]() I want a 2wd Blazer. Slonaker |
#16 |
mine will be stock hieght when done, but i really like the way yours turned out....hmmm
#17 | |
#18 |
i've got the 1985 k5 blazer and i was looking to slam it too but not quite as low as urs lol no money for bags and it needs to be my daily driver
#19 |
Do you mean you made a 4x4 into 2wd. No offense but WHY?????
#20 |
Is it possible to just join the front part of a 2wd frame(with suspension and all) to a 4x k5 and welding it/boxing it in? I've seen guys use Camaro/Monte Carlo front ends on older pick ups..
On a lighter note, if anyone has a 2wd rolling chassis for sale, I'm interested in one.. Last edited by blazekraze; 10-05-2005 at 11:12 PM. |
#21 | |
#22 | |
I think if you cut the rivets off that hold the 4wd front "A" frame(?) in place you can then bolt on the 2wd "A" frame and suspension. Not exactly sure, but this is what I believe. Its been covered pretty good in at least the past year or so in the Blazer forum.
I'm not sure if you need to remove the front spring mounts or not? And I also think you have to replace the rear spring mounts as they have a different offset. Again, not exactly sure. Oh, and you will have a different hump in the floor for the transfer case. Best advise I got was to find a donor truck or idealy a Suburban - the Sub's have heavier brakes and such for a little better preformance. Take all necessary parts from the donor. Which makes me wonder why Milehigh did the body swap and not just swap the suspension? Quote:
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#23 | |
Oh yeah, 4wd's are literally a dime a dozen. 2wd's are a bit harder to come by.
I have a 2wd project in the for sale section...... Quote:
#24 |
Hey, I have a two wheel drive truck swb and I want severely to trade for 4x4 in alright shape. There is nothing wrong with my truck but nobody will trade and around here everybody want 4wd. I just bought it because good deal. What did you do with 4wd chassis
#25 | |
Wish you were closer to me, I'd buy it in a heartbeat, I have an uncle who drives an 18 wheeler and if he'd go up to Wash. I'd have him get it.. |
