Old 09-16-2005, 09:58 PM   #1
kwmech
Big block mounts
Looking for the RUBBER the 2 piece kind from 68-71. I am looking for new. The GM dealer doesn't have them anymore and there is no listing at NAPA. What I am doing is moving my small block backwards with the big block stands so the fan will sit in the same place with the serpentine kit. I already have to do the exhaust anyways and I am putting in a gear vendor.
Old 09-17-2005, 09:10 PM   #2
kwmech
33 lookies and no answer? Somebody has to have an idea
Old 09-17-2005, 10:39 PM   #3
corn
I installed a small block in the stock location using all of my stock big block mounts. Rubbers and all. I went to get a new rubber mount & they showed the newer style mounts for the 396 but showed the one I needed listed under 6 cyl. I got it at O'rielly auto parts. It may be worth going back to check...corn
corn is offline   Reply With Quote
Old 09-17-2005, 11:20 PM   #4
kwmech
I am using the big block steel frame stands, so I need the big block cushions--upper and lower.
Old 09-17-2005, 11:39 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
We are doing a search and have found one set so far for one of our Canadian customers. I may have a couple more coming. These have been discontinued now from GM and so far nobody that we know of is reproducing them. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-18-2005, 01:00 AM   #6
BIGJAKE97
BIGJAKE97's Avatar
lmc has them, part #34-0329, their price is$79.95 plus shipping. that's the spring 2005 (cb.40) catolog. I just happen to find a summer 2001 catolog first and the price is 39.95, wow. If you don't want to order from the idiots at lmc, bill at vintage chevy trucks, 510-651-5874, in fremont ca, should also have the mounts. the mounts are made in india, not tawian, isn't that a surpise. Make sure you tap the nut in the mount before you start a bolt in it, you won't be happy with the results if you don't! hope this helps. good luck!
67 short fleet
71 blazer 4x4
72 blazer 2wd
76 gmc sierra 3/4t 4x4
62 bel air
01 blazer extreme
member 11,943!
BIGJAKE97 is offline   Reply With Quote
Old 09-18-2005, 12:16 PM   #7
kwmech
Thank guys, I'll make some calls on monday.
Old 09-18-2005, 02:02 PM   #8
uncle
Mounts
I got some from Pickmup.
uncle is offline   Reply With Quote
Old 09-18-2005, 03:16 PM   #9
gregsplace
gregsplace's Avatar
I've ordered mine from GMCPauls.
67 3/4 4x4 402,a/t,flat bed
98 GMC Sierra swb daily driver
87 burb parting out.
68 1/2 chevy, 350/350, 71 gmc frame, kid's beater
69 1ton 396-4sp, dump
69 swb stepside 396/400th current frameup
67 swb 454/400th rebuilding now, oldest boy just rolled it
99,HD, Road King Classic
Colwich Ks
gregsplace is offline   Reply With Quote
Old 09-18-2005, 05:09 PM   #10
David Johnson
David Johnson's Avatar
You can use pads from a small block. All you do is use a bigger washer. Txfirefighter posted a how-to thread on this. I did it, worked great, cost about $20 (and I had a pair of big block cushions).
David Johnson is offline   Reply With Quote
Old 09-18-2005, 07:05 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's in the FAQ section....
