Old 09-17-2005, 12:43 AM   #1
MrC1
Dork For Days
MrC1's Avatar
Question How do ya drop the rear of a C20 with leafs 2"?
Sorry for the barrage of questions!
I know there's lots of threads about this, but I couldn't find this specific answer.
I've got a '72 C20 with leaf rear suspension (HD option?) Anyway, I want to leave the ride height stock for now, 'cept I'd like to drop the rear 2" to level it out. How's this done? Are there 2" longer shackles available? If so, where?
It appears that 2" longer shackles might not quite fit under the bed, but I'm not sure. It's a fleetside metal bed, BTW.
MrC1 is offline   Reply With Quote
Old 09-17-2005, 01:42 AM   #2
69 Short Fleet
Not sure on a C/20. I just got Early Classics catalog today and they only offer leafsprings (with drop) for C/10's. I don't remember seeing anything for the 3/4 tons from any vendors. Doug
69 Short Fleet is offline   Reply With Quote
Old 09-17-2005, 01:56 AM   #3
tomatocity
tomatocity's Avatar
Check the catalogs or contact one of the Board vendors like GMCPauls or any of the others. They are all good companies with good employees.
How wide are your leaf springs? What is the length (bushing to bushing) of your leaf springs. My leafs are 2.25" wide adn approx. 51+" long (bushing center to bushing center).
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 09-17-2005, 02:45 AM   #4
llegos
take out a leaf?
-Steve
llegos is offline   Reply With Quote
Old 09-17-2005, 05:42 PM   #5
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I'm lookin at raising the front. Still playing with these http://www.classicperform.com/Store/...k/6372SHKR.htm
Tomatocity and I have talked about it before. Spring dimensions will be important to make sure the shackle will fit. Talk to tech support of whatever company you choose.
chickenwing is offline   Reply With Quote
Old 09-17-2005, 06:11 PM   #6
69 longhorn
For such a minor drop,possibly rearching the springs may be the best route.you will still have the load capacity, & no issues with longer shackles/box floor clearance. best of luck, 69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 09-17-2005, 07:00 PM   #7
72MARIO
72MARIO's Avatar
That would be "dearching" Longhorn
Any local spring shop will pull the pack and flatten them out 2" usually under $100.00.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-18-2005, 11:42 AM   #8
chickenwing
Didn't know that was a common thing. Thought it was a "lost art". I love this place. Thanks for the thread and info.
Old 09-20-2005, 10:37 PM   #9
MrC1
Dork For Days
MrC1's Avatar
Thanks for the info!
Thanks for the info guys. I was hoping to hear that a longer shackle was available (or somethin gsimilar), but maybe it's not. I've searched all over, but haven't found anything.
I may end up rearching the springs, but I'd prefer not to.
Old 09-21-2005, 12:27 AM   #10
masterbeavis
Having issues
masterbeavis's Avatar
Dumb question, but is you axle spring under or spring over? Not knowing much about somethings maes me have to ask. If it was sprung under, you could put a block in there lowering it more??!?!
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-21-2005, 02:00 AM   #11
1969 GMC
1969 GMC's Avatar
They're sprungover.
My personal suggestion is, a bed full of bricks.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-21-2005, 02:05 AM   #12
XXL
Seņor Member
XXL's Avatar
Longer shackles will take you the wrong direction.
Ray's Fort Worth Champion Spring. Have them dearched to whatever ride height you want. You'll maintain the mechanical integrity of the spring pack (load capacity, spring rate, etc.), which will be altered substantially if you start pulling leaves out of the spring pack.
XXL is offline   Reply With Quote
Old 09-21-2005, 12:07 PM   #13
Maximum Overdrive
December 21, 2012
Let the air out of the rear tires until you achieve the 2 inches.
Not sure how yours is set up but mine has overloads on it and by simply taking out the overload springs and the spacer and then using new u bolts I could acheive 2-3 inch drop on the rear of my truck.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 09-21-2005, 01:40 PM   #14
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
I took my truck to a spring shop and they removed the leaves and individually de arched each one. I do not know how much it changed the amount of a load I can haul.
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 09-21-2005, 01:48 PM   #15
tomatocity
tomatocity's Avatar
Probably less expensive if you removed them yourself and took them into the shop. May I ask what the cost was?
Old 09-21-2005, 08:44 PM   #16
MrC1
Dork For Days
MrC1's Avatar
Lightbulb Shackles are okay.
Actually, they hang DOWN to the springs, so longer ones WILL work.
Old 09-21-2005, 08:46 PM   #17
MrC1
Dork For Days
MrC1's Avatar
Hmmm...
I've got the overload springs too, but that's only about 1/2"-3/4" of thickness. I'm not sure what spacer you're referring to.
Old 09-21-2005, 10:52 PM   #18
XXL
Seņor Member
XXL's Avatar
I guess I'm missing something. If the shackles connect on top at the frame and on the bottom at the spring, making them longer lowers the spring mount, which is the same as raising everything above the spring mount. It's been a while since I've looked at a leaf version of thse trucks, but I believe the spring eye is on the low end of the shackle.
Old 09-22-2005, 09:21 AM   #19
69 longhorn
Your sketches show how most of the mid 60's leaf sprung muscle cars were set up. longer shackles did lift them. the trucks are setup differently tho......the spring is above the frame perch, & the shackle drops from the spring eye , down to the perch. longer shackles do lower a truck, but how far you can go without hitting a cross rail , or the bed floor doesnt work to be much more than 1" or so(depending on wood, or steel floor). If you can get enough drop with a shackle.....I would sure go that way, as it would be by far the easiest route L
Old 09-22-2005, 08:04 PM   #20
MrC1
Dork For Days
MrC1's Avatar
Question Where though?
Where can I get longer shackles though? Anybody make them?
Old 09-22-2005, 08:12 PM   #21
69 longhorn
C-20, should be a 2 1/2" wide leaf.....try Bell tech on the 73-up trucks, it should be the same deal. if that does not work, a good welder/fab man can "hook you up". Best of luck, L
Old 09-23-2005, 01:21 AM   #22
tomatocity
tomatocity's Avatar
Rich these are drop shackles and they would lower your truck. I think we should slam your truck and leave the same wheels and tires on it
Old 09-23-2005, 01:26 AM   #23
tomatocity
tomatocity's Avatar
Use the link to CPP that chickenwing posted. They allow you teh option of either 1" or 2".
Old 09-23-2005, 08:34 AM   #24
chickenwing
What's next? Dingo balls?
Old 09-23-2005, 10:53 AM   #25
XXL
Seņor Member
XXL's Avatar
Aha! I thought I was missing some fact... thanks for the clarification.
