Old 09-17-2005, 02:57 AM   #1
matt67350
matt67350's Avatar
Talking Headlight relay install You Gotta do it.
Just finished installing a relay in the high and low beam lights, on a 69 lwb.
If you have not done this install, you should. This is the second truck I've done.
Cost is about $25.00-$40.00 depending how much wire, relays and split loom
you want to replace. This mod will payoff rightaway.
Bright light,
Matthew
matt67350 is offline   Reply With Quote
Old 09-17-2005, 03:13 AM   #2
raidermanny
raidermanny's Avatar
what exactly does this do
raidermanny is offline   Reply With Quote
Old 09-17-2005, 03:51 AM   #3
aquik72gmc350
It makes your headlites alot brighter.
aquik72gmc350 is offline   Reply With Quote
Old 09-17-2005, 05:00 AM   #4
4x4Poet
Here ya go:
http://www.madelectrical.com/electri...adlights.shtml
One of the best mods for nightime visibility and safety. Also upgrade to high quality halogen or better headlights and you'll never hit a deer on a pitch black night. Or a pedestrian (unless on purpose ).
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-17-2005, 05:35 AM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
Bright light,
Matthew
its on my list of things to do to the truck
tnblazerk5 is offline   Reply With Quote
Old 09-17-2005, 09:54 AM   #6
mrein3
mrein3's Avatar
Your factory truck headlight wiring sucks. You have 12 volts running from the battery, to the switch on the dash board, back to the headlights RIGHT NEXT TO THE BATTERY!
The wires are too small, the length is to great, the result is less than 11 volts at your headlights.
And all that missing current has to go somewhere. Where it goes is it turns into heat which wears out your $8.00, pain in the a$$ to change headlight switch!
What you do is turn your headlight switch into a relay controller. Use 8 or 10 gauge wire from the battery through the relay to the headlights. The result is 12+ volts at the headlights. The first night you run with these you'll wonder why you waited so long to make the swap.
You'll also wonder why people are buying those $40 each headlight "upgrades".
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-17-2005, 10:53 AM   #7
cdowns
cdowns's Avatar
works on the backend too
Old 09-17-2005, 11:24 AM   #8
FormerMember
Also, 17.50 if you want to go the Summit route:
http://store.summitracing.com/partde...sp?part=108995
FormerMember is offline   Reply With Quote
Old 09-17-2005, 11:52 AM   #9
67chevemall
67chevemall's Avatar
ya its on my list too! I want to do alot of rewiring I should just do iteh.
The summit one looks good..
67chevemall is offline   Reply With Quote
Old 09-17-2005, 11:53 AM   #10
70c10
67-72 Addict!
70c10's Avatar
I was planning on buying one the headlight upgrade kits and didn't realize I would be frying the headlight switch over the long term!. I will look into that kit from Summitt.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-17-2005, 11:31 PM   #11
KEH
Better late than never
KEH's Avatar
Has anyone used that summit kit? Just wondering if the wire lengthes and all are good?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 09-17-2005, 11:40 PM   #12
hilljob26
hilljob26's Avatar
anyway you can make a wiring diagram for us,i have a couple extra relays and would like to run them the way you did
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-17-2005, 11:46 PM   #13
mikesgmc68
no headleads
See here everyone talking about the headlights. I am handy, but when it comes to wiring, i have to left hands. I think this may be my problem. I put a new high/low switch in as well as a new h/lamp switch. I have dash lights, tail lights, directionals and brake lights but no h/lamps either high/low beam. Any info on what I am facing here would be great. Thanks to all for any input.
mikesgmc68 is offline   Reply With Quote
Old 09-17-2005, 11:51 PM   #14
71swb4x4
71swb4x4's Avatar
I have done it, can't believe anyone with a daily driver that sees night driving wouldn't do it. It makes night time driving 10 times better. One of the cheapest bangs for your buck.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-18-2005, 12:25 AM   #15
Russell
Professional Grade
Russell's Avatar
Man, with all this talk, its looking like my headlight system is getting a second and third relay, lol (I've got it rigged up so the headlights are on when my heater fan is on, that turns them off when you are cranking, but on the rest of the time)
My lights were good before, I'm excited to see how they'll be after I do this little upgrade! I never even thought about doing so before
I think these will be relays number 20 and 21 or so on my truck, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-18-2005, 01:08 AM   #16
aquik72gmc350
Chevy is the first, and GMC is the second.
Old 09-18-2005, 07:40 AM   #17
vtblazer
vtblazer's Avatar
Good tip/info, thanks.
Appreciate the link.
Just ordered the Summit kit.
vtblazer is offline   Reply With Quote
Old 09-18-2005, 08:06 AM   #18
nitor
Too many projects
nitor's Avatar
This is on my list.
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 09-18-2005, 08:27 AM   #19
70GMCer
70GMCer's Avatar
also at JEGS......... http://www.jegs.com/cgi-bin/ncommerc...10&prmenbr=361
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-18-2005, 08:38 AM   #20
Sweet72
Sweet72's Avatar
The GMC schematic has only one 20a fuse feeding 4 headlights. For better circuit protection use two on the feed wires like the Chevy.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 09-18-2005, 08:51 AM   #21
1972ChevyCheyenne
What relay would be good for this? Anyone have a part number?
Jamie
1972ChevyCheyenne is offline   Reply With Quote
Old 09-18-2005, 09:01 AM   #22
FormerMember
I've done it on several trucks.
(the summit one)
Lengths are perfect, in fact, too long. I usually cut 'em down.
A bosch relay, in 20 amps is perfect for DIY.
Old 09-18-2005, 09:25 AM   #23
67chevemall
Jegs kit looks like it comes with better bulbs too? You don't have to change the
bulbs too do you?
Old 09-18-2005, 09:27 AM   #24
Curbstone Mech
Active Member
I went with the mad electric kit a few months ago, came with diagram and all.Well worth it
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 09-18-2005, 09:58 AM   #25
FormerMember
bulbs too do you?
Summit one has no bulbs. We were discussing just wiring, which is a SIGNIFICANT improvement.
Do you have sealed headlights? If so, no bulb replacement.
I've also used the Sylvania upgrade (cool whites? They suck) and the Hella one. Hella makes a better light, with replaceable bulbes that uses a H3 headlight bulb with an open housing.
http://store.summitracing.com/defaul...=egnsearch.asp
AND if you're really mean, you can put the "offroad only" bulbs in there...
