Old 07-03-2002, 08:04 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Question later model posi fit in a 70?
Will a 1978 6 lug posi with 3.73 fit my 70 6 lug?. What mods would I need to make?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-03-2002, 08:50 AM   #2
JimKshortstep4x4
Smile
If the posi carrier and gears are out of a 12 bolt truck rear end it should be a direct replacement. I believe that the axles out of the later model are longer but the 70 axles will have the same spline.
Jim
Old 07-03-2002, 09:10 AM   #3
70c10
67-72 Addict!
70c10's Avatar
It is a 12 bolt just like mine. Will I just use "my" axles?
Jim
Old 07-03-2002, 12:09 PM   #4
JimKshortstep4x4
Smile
You can measure to make sure if they are the same length or not, but yes you can use your axles. Sometimes the axle bearing surfaces are spalled and the axle needs to be changed, so it is worth checking just in case you need one.
Jim
Old 07-03-2002, 03:05 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Thanks Jim
Jim
Old 07-06-2002, 05:37 PM   #6
Fast68Chevy
Fast68Chevy's Avatar
12 bolt internals are same, stay away from van 10 series axles though, they are only 2400 and 2900lb rated, the K10 are 3300 rated and ours in C-10 trucks are 3500lb and the van 20 series are the heaviest at 3600lb, G20 are 12 bolt also, this applies to all years of ther 12 bolt, '64-82
70-82 12 bolt pickup sjafts are same length, all 12 bolt at least 3300-up are 31 spline, cant say for sure on van ones, as i have run into a 17 spline pinion yoke one(2900lb) so.,,,,,, :S
Fast68Chevy is offline   Reply With Quote
