![]() Join Date: Feb 2004
66C10 Power Steering
What later model power sterring gear will bolt up to a 66 column shaft? Or how did you complete this task?
thanks |
none will bolt up. you can use the "rez"conversion kit to use a 71-87 power steering box.it requires minor welding.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
YES_____NO
![]() Join Date: Jul 1999
Brothers sells a kit that requires no welding, just have to drill one extra hold in the frame
![]() Power sterrung Adapter kit
![]() People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
I believe the welding zenish was reffering to is when you cut the steering column rod....due to the power steering box being longer than the manual box...
I believe that Brothers kit and the Rez Engineering are the same thing. Check out www.americanclassic.com, I remember seeing they have pre-made column shafts the right length, so you don't have to cut up yours if you aren't experienced at welding.
or u can swap steering columns i got a 91 sub column in mine no welding.
65 c10 tore apart 70 c10 305/350th |
chevy283 --got any pics----thanks
I never welded anything. I put on the rez eng kit with a mid 85's box and used a stock intermediate shaft (the collapsible type) new rag joint. 68 tilt column
no it looks cool though. Check out this site he used a 80s sub colume. http://geocities.com/vapershing/pickup.html
65 c10 tore apart 70 c10 305/350th Last edited by chevy283; 09-20-2005 at 06:19 PM. |
