Poly Body mounts for K-5
Does anyone make/sell polyurethane body mounts for 69-72 Blazers? All I've found in the catalogs I have are the rubber ones.
![]() Join Date: Dec 2002
Tons of people sell them. Look up Raybucks They are in PA Close to us. $90 can get in a day or two
You can get the poly mounts for a 4wd but not a 2wd kit. You will have to buy a 4wd kit I guess and then ask them if you can get just the front core support kit for a truck or something.
Thanks for the info. Raybucks does have them, but they are listed for a 4wd. I would suspect they'd also work on my 2wd, but does anyone know for certain if there are any differences between the two?
The body portion of the body mounts are the same, the only difference is in the core support but I think you can buy only the core support set up seperate from the vendors for a truck. I bought the rubber ones again for mine. I had heard that some guys on here didnt like the poly bushings because it made the ride more harsh.
Thanks for the info! I'm not too worried about the ride being too harsh- eventually I'm going to be putting an air suspension on the truck and the whole suspension will be changed. For now I need to get new mounts on there because my old ones are shot, and since I have it all apart right now I might as well put them in there.
