09-18-2005, 03:48 PM | #1 |
I need Part #'s for wheel bearings
I'm rebuilding a front end, and I don't have the exact year of the truck. I need to gets part #'s for the inner and outer wheel bearings, and seals for:
1/2 ton C-10 any year I have the old Bearings but the #'s don't cross refrence to anything. |
09-19-2005, 09:52 AM | #2 |
I would bring them to the store with you. Make up a year and match up the set they give you.
09-19-2005, 11:14 AM | #3 |
aquick i have all the bearing you speak off just cleaned and put in new zip lock bags i can get the numbers you need this evening or maybe at lunch? keep in mind these are the bigger 1/2 ton front end i believe 1-1/4 rotors i will let you know asap P.S. they are out of an 85 swb if this matters
square body trucks an addiction or an investment either way they consume all my extra time and money |
09-19-2005, 12:39 PM | #4 |
yeller
Call NAPA, they should be able to help you. Just tell them you have a 82 Chevy ....
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-19-2005, 01:33 PM | #5 |
Insert Witty Text Here
When I replaced my wheel bearings, they needed to know my brake option, JB?, with the ? being a number. I knew I had light duty brakes, but they could not tell me anything at any of the local stores without the numbers. I had to just take them in, look up both brake options, and match them up visually.
Slonaker |
09-19-2005, 02:59 PM | #6 |
For my truck, I bought Federal Mogul bearings at O'Reilly. The outers are part number A3 for either disc. The inners are part number A6 for the 1" rotors, or part number A5 for the 1-1/4" rotors (yes, I got the wrong ones the first time ). The inner seal was part number 8871, but I forget what brand that was. These part numbers are for 1/2 ton 2WD.
- Greg |
