Old 09-18-2005, 06:32 PM   #1
Fastfun
Fastfun's Avatar
porting and polishing
I am planning on porting and polishing the heads on the motor that I will be putting in my truck(94 LT1 aluminum head). I found this link on how to port and polish and I thought I would share with other board members. Has anybody attempted to port and polish their heads and did they have any problems and was it worth the effort.
Enjoy
http://www.sa-motorsports.com/diyport.shtm
Fastfun is offline   Reply With Quote
Old 09-18-2005, 06:45 PM   #2
GenIIIShorty
JUNK COLLECTOR!!!!!
GenIIIShorty's Avatar
that's a sweet link!
baby
The dark side! 2000 XLT PSD F-250 4x4! Offroad package
1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3
GenIIIShorty is offline   Reply With Quote
Old 09-18-2005, 07:19 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
Yeah, I've done it on 351C 4V heads. Hell, I even polished the lifter valley to a mirror finish to help oil drain back more quickly. It's a lot of work and quite honestly, unless you're building a race engine time is well spent elsewhere.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 09-18-2005, 07:33 PM   #4
72CSTC5
72CSTC5's Avatar
Mocwon, you do not think you will see that much more power by doing this? How much horsepower do you think it is worth?
72CSTC5 is offline   Reply With Quote
Old 09-18-2005, 07:39 PM   #5
cornutz
All Praise RANDY!!
cornutz's Avatar
It is a lot of work, but if you are looking to gain those few horses here and there (ie: headers, intake manifold, etc...) it is worth it... probably in the range of 18 to 20 horsies easy... depends on valve job too...I like to think that it is just something you would want to do to make your motor flow better, I guess it depends on the $$ vs. time thing though too. How much is your time worth?
Just my .02
cornutz is offline   Reply With Quote
Old 09-18-2005, 07:44 PM   #6
clay68c10
clay68c10's Avatar
I did a basic gasket match and just hit the high spots and casting crusties in my 454. No real problems other than it makes a hell of a mess. I did it all at work so as not to piss off all the neighbors with the die grinder. If you really compare the ports to the gaskets, there can be a pretty big difference as far as the smoothness of the transition from intake to head. It doesn't seem like GM was all that precise with their port castings in the old days. Your engine is a lot newer and it probably is pretty well matched up.
I say go for the gasket match and just knock down the crusties. Any more than that is a waste on a street engine.
Be sure to get the cutting heads designed for aluminum, the steel ones will load up with the softer metal and are difficult to clean out.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-19-2005, 08:50 AM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
Port matching is worth the time and effort.
Just Passin' Thru
Old 09-19-2005, 08:51 AM   #8
mocwon
Keep On Truckin'
mocwon's Avatar
Can't say without dyno runs before and after. But, if I had to guess, maybe 15HP.
Just Passin' Thru
Old 09-19-2005, 08:57 AM   #9
cdowns
cdowns's Avatar
one thing to keep in mind is that if you get carried away with the grinding wheel you can end up with a very expensive door stop
Old 09-19-2005, 05:35 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Link, Mine was done by a Professional, not taking anything away
from you do it yourselfers, but Like DOWNS said, u can go 2 far w/ it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-19-2005, 05:44 PM   #11
Mad Dog
Mad Dog's Avatar
I've been porting my junk and other people's junk for a few years......my best advice is to take it slow, keep it simple and prepare that it will take some time. Start with a grinding wheel untill you get going, a carbide bit will remove too much too quick for a novice.
I would gasket match the intake, smooth out the chamber, and smooth the runners. That is a great start. Only attempt the short side intake radius and the valve guides if you feel very confident, or need an expensive paper weight.
72 C10 longbed 5/7 drop, Telstars, 350/th400(for now)
69 Chevelle SS396 (427/th400)
88 K5 on 35's (355/700R4/208)
Mad Dog is offline   Reply With Quote
Old 09-19-2005, 07:26 PM   #12
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Hey...nice link I will save that...thanks!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-19-2005, 10:31 PM   #13
Stroker
I'm not an expert by any means but I have done a fair amount of reseach about cylinder head porting.The LT1 head is a very decent flowing head as it came from the factory and can be improved on significantly with proper porting.But, as already pointed out it can be turned to junk in a hurry also. There are a number of different cylinder head and port designs and they all require slightly different porting to get good results. The type of porting done on a 186 head that produced exellent results may actually cost you power on an LT1 head.
My advice would be to continue to look for information specific to the LT1 or Vortech heads before you go at them with a grinder. My understanding of these heads is that the runner and port design as well as the casting quality was very good from the factory. Mild porting usually does not produce the 15-20 HP that it does on the older and cruder castings. Usually more like 0 plus or minus 10HP. There may be another 10 HP or so to be gained by the proper valve job also.
If you get more aggressive then you better know what you doing and have a proven port design that you're reproducing.
This book is a good one to have read if you plan on doing any porting and has some information on the Vortech cylinder head which shares much of its design with the LT1.
http://www.amazon.com/exec/obidos/tg...97554?v=glance
Here are a few more links:
http://www.chevyhiperformance.com/techarticles/95518/
http://www.babcox.com/editorial/us/us110128.htm
http://www.ws6transam.org/ported.html
http://www.gmhightechperformance.com/tech/0504htp_lt1/
http://chevyhiperformance.com/techar...8_0507_vortec/
http://chevyhiperformance.com/techarticles/46364/
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 09-20-2005, 03:22 AM   #14
69 Short Fleet
Great links! Every small amount of horsepower adds up imo.
69 Short Fleet is offline   Reply With Quote
