Old 09-18-2005, 07:54 PM   #1
CAL 58 GMC
CAL 58 GMC's Avatar
Brake line help
I need some help on getting the right size brake lines. I have 58 GMC that has a Camaro clip up front and a 2003 Blazer rear dif. I have TCI's 55 to 59 frame mount power boaster and a Corvette style master cylinder. Does anyone know what size lines I neet to run?
CAL 58 GMC is offline   Reply With Quote
Old 09-18-2005, 08:48 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
They should be 3/16 for disc and 1/4 for drum. The 2003 blazer may be metric so you would need a metric fitting and the equivalent size tube. If you go to http://www.fedhillusa.com/pages/709975/index.htm you can get some brake line that works very well and is much easier to flare. They also have the fittings you will need.
dwcsr is offline   Reply With Quote
Old 09-19-2005, 03:32 AM   #3
CAL 58 GMC
CAL 58 GMC's Avatar
Thanks dwcsr for the info!! I really appreciate your responce! I will check that link out.
