Old 09-18-2005, 08:00 PM   #1
76bonanza
76bonanza's Avatar
brake line question
One of the metal brake lines that run to the rear brakes is so close to the header you can not see light thru it. This is not good is it? Or am I make it out to be worse than it is? brakes seem to work fine even after a 200 mile trip?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-18-2005, 08:16 PM   #2
4tiresngas
An American Soldier
4tiresngas's Avatar
I have seen other posts on here about the brake lines (ones coming from the master cylinder and the the one bending around the frame on the passenger side) being close to the exhaust. I don't think the heat is that bid a deal. However, I would not be real comfortable if they are touching. The engine and exhaust do move and I would not want anything rubbing on a brake line over time. My .02
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 09-18-2005, 08:19 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
heat will boil the fluid try to get it away from the heat source as far a possible
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
