Old 09-19-2005, 09:10 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Ground for the Radio?
I think I have a loose ground on the radio, it cut in and out for a while, now it is just out. It is an aftermarket in the original place with only one speaker. If he used the same Ground as was on the original where would it be and what is the easiest way to get there. If someone could save me about an hr of exploration that would be great!!
O Yea, 71 C10, 3 spd , 350 with an AC Cab. SWB but I dont think it would be grounded to the bed
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
Last edited by phlegm; 09-19-2005 at 09:32 AM. Reason: Clean up the Grammer, ugh..
phlegm is offline   Reply With Quote
Old 09-19-2005, 09:26 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
I ran a ground to the dash for mine. I pinned it under the screw that holds the ashtray in.
My amps are under the seat and are grounded to the cab floor.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-19-2005, 09:27 AM   #3
shifty
Questionable
shifty's Avatar
Under my A/C controls panel, I have two screws into the dash. I used one of those to ground to. Then I mounted a 3-gauge panel using those holes (not sure if they're stock?) for temp/oil pressure/ammeter.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-19-2005, 10:47 AM   #4
djracer
djracer's Avatar
I'd take a meter or test light and check power first! Most radios will have a yellow constant 12v and a red switched 12v! It must have both of these powers to operate! If it has both powers just reground it to anything metal and you should be fine.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-19-2005, 03:36 PM   #5
phlegm
phlegm's Avatar
Any idea where the Stock Ground would run to? I think I only have switched 12 v but I will have to look, its an older am fm cassette with no clock or digital features.. spin the dial to get the station. Is there an easy way to the radio to check the wiring? I am guessin since I have a factory AC it is going to be a bit of a pain.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-19-2005, 08:24 PM   #6
chops333
i think the factory ground is built in to how the radio is mounted my factory radio am has 3 wires 1 power 2 speakers thats all hope this helps.
chops333 is offline   Reply With Quote
