Old 09-19-2005, 07:16 PM   #1
Goffer
Goffer's Avatar
Oil Pressure
Just put in a new MSD distributor and now the oil pressure gauge reads zero unless the engine is wound up to 4,000 the the needle will come off of the post. Everything mated up just fine with the distributor and the oil pump. the sender for the pressure gauge is right behind the intake manifold on the block. What's going on?
'71 C10 swb 350sb/700r4
Goffer is offline   Reply With Quote
Old 09-19-2005, 07:21 PM   #2
dwaite72lnghrn
Are your valves tapping when the pressure is 0? If so the oil pump shaft dislodged. If the valves don't tap I guessing the oil pressure guage wire (aftermarket) or oil tubing is bent pinched or broken.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 09-19-2005, 07:27 PM   #3
68 short step
so you are running a electric oil press guage? my first step would be to make sure you actually do have oil pressure.easist was is pull of v/c and start the engine and see if oil is shooting from the rockers. if it is, you have o/p. if it is then i would say there is a wiring issue. if it doesnt, then id pull the dissy and spin it with a drill and see if you have the same result.
68 short step is offline   Reply With Quote
Old 09-22-2005, 12:04 AM   #4
Goffer
Goffer's Avatar
oil isn't "shooting" but there is pressure. I have the sending unit mounted next to the distributor. Would another location like next to the oil filter be more accurate? and lastly is it is just a low oil press problem would a new pump be the answer or should I look in other areas first?
Old 09-22-2005, 12:48 AM   #5
Goffer
Goffer's Avatar
where do you all have your sending unit mounted?
Old 09-22-2005, 01:03 AM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
mine is next to the dizzy
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-22-2005, 07:15 AM   #7
OLDCHEV4X4
OLDCHEV4X4's Avatar
Hook up the original guage and see if it has pressure.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
