Old 07-03-2002, 01:15 PM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Aftermarket AC Kits
I'm getting ready to start the frame off resto and I want to add AC. Has anyone used the kits from Vintage Air or Arizona Mobile Air? Which is best? Any and all input would be greatly appreciated.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 07-03-2002, 01:29 PM   #2
72ChevyCheyenne
Aftermarket AC Kits
Bill Durham
72 Cheyenne
Old 07-03-2002, 02:10 PM   #3
Blue68
Blue68's Avatar
Used Vintage air. Very happy. You will be challenged to seal up the air leaks on these old beasts if you want to keep your cool in the truck though. I found that at highway speeds I didn't stay real cool even though the air from the vent was frigid. At slower speeds I was good.
Only complaint I had was the Sanden compressor was a little noisy for my taste. The Vintage Air tech said it was the same on his new Honda Accord. So now I have an oem compress i'm going to try running out of a '98 truck, but I didn't swap engines just for a new compressor.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 07-03-2002, 02:33 PM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Also look into "Old Air" units.
Great product & Customer service.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 07-03-2002, 04:27 PM   #5
Frank_Zeller
Frank_Zeller's Avatar
Got the Old Air setup....took some tweaking to get it right. Some my falt Happy with it now. You must fix all the air leaks and add lots of insulation. I still have not found all the air leaks even with all new weather stripping and silicone the vent windows. Have pics of the installation if you’re interested. Call old air and they will send you a catalog I mounted the compressor cycle temp switch where the lighter was. This allows me to change the vent temp from 60 to 38 F.
Pros
Old Air did not charge me until they shipped
Cold vent air
Pretty straightforward install
Compressor and bracket low profile
Blower pulls though the evaporator (vintage air pushs the air thought) this might make it quiter?
Has full size condenser in front (vintage air one is about a 1/3 smaller)
Cons
Compressor a little noisy above 2500 rpm
Blower makes some noise
Center vent only has one feed in.....factory has 2.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 07-04-2002, 04:35 PM   #6
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
JUST dropped my Burb off to have the under dash a/c installed, goin with the AMA setup. We leave for Ga next Monday, (7/15) THAT my friend will be a true test of an a/c unit!!!!
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 07-04-2002, 04:48 PM   #7
nroden
nroden's Avatar
Here you all all have aftermarket setups and my stock 1972 AC still runs. It hasn't been put to the test yet going down the highway because I haven't had it on the highway during the summer. It does cool though sitting.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 07-06-2002, 07:04 PM   #8
jlmtrout
I'm very happy with Old Air. Everyone is right about air leaks and insulation. Very cold air out of ducts. Once you get rid of the hot air in the cab, it'll keep you comfortable. Also, consider the R-134. You can buy it over the counter and is ozone friendly. Not too difficult to install, hardest part is cutting holes in the dash for the vents, and will clean up your firewall by eliminating the "doghouse". Good luck and keep on truckin'!---------Jerry
jlmtrout is offline   Reply With Quote
