Old 07-03-2002, 01:35 PM   #1
Erl
Erl's Avatar
How to treat old rubber
I have an original 4x4 transfer case shift lever boot that is in good shape except that it is dry and becoming brittle. What should I put on it to soften it up, since they can not be purchased new.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 07-03-2002, 02:32 PM   #2
highwaydevil
Try calling a GM dealer, they have some stuff for weatherstripping that is supposed to keep it soft on new cars, may just work to get it soft again.
highwaydevil is offline   Reply With Quote
Old 07-04-2002, 03:22 PM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Ammonia will soften rubber, get it fron blueprint supply shops.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 07-04-2002, 03:44 PM   #4
RALLY FAST
RALLY FAST's Avatar
try petroleum jelly put it on all my window rubbers on the 71truck in 96 still looks good soaks in best to do it on a hot day
69 SHORT FLEET SIDE MAROON RESTORED.
71 LONG FLEET RESTORED D/DRIVER. BUT ALWAYS LOOKING TO IMPROVE 68 SHORT UNDER CONSTRUCTION
RALLY FAST is offline   Reply With Quote
Old 07-04-2002, 09:17 PM   #5
Don Smith
Silicone grease works for me.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 07-04-2002, 10:47 PM   #6
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Just turn them inside out and use em again! Thats what I do!
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 07-05-2002, 10:20 AM   #7
johnnyp
Keepin' It Stock
johnnyp's Avatar
Not something I'd recommend imaindianoutlaw, unless you're doing the job by hand.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 07-05-2002, 10:25 AM   #8
WB72
Before and After
WB72's Avatar
Cool Imaindianoutlaw
Were you talking about your underwear?
LOL!
:p
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 07-05-2002, 10:44 AM   #9
Low69CST
Start soaking it in some kind of rubber dressing like armorall. Apply it once or week or every couple of days. It should bring some life to it.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-05-2002, 03:55 PM   #10
jku72
3M makes a really good silicone rubber restorer, I wish I could remember the name, the tube is sitting at home on a shelf, I use it on rubber as old as 1940, and while it isnt magic, it works better than anything else Ive ever seen.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
