72 Burban Parts for Sale
All parts from 72 Suburban
1. Rear lighting harness from fuse block/dash connector to lamps including A Dome light harness B Rear body harness - dash connector to rear lamp connector C Fuel tank sender harness D License plate and fuel tank extension harness E Left and right light harnesses(tail, brake, reverse, and marker) All terminals included. No breaks, cuts, or splices. Checked for continuity. Factory wrap intact. $100 plus shipping. 2. Suburban 3rd door panels. Left and right interior door panels - base model(plain) Medium green but PO sprayed light grey(primer???). All attaching clip slots are intact(none broken). One extra hole on passenger side for mounting screw - similar to front doors. Good condition - some scraps but no cuts or cracks. $150 plus shipping. 3. Tailgate - above average condition - no rust. Inside has several dings and bends but a stud gun/slide hammer would make an easy fix. Lock is locked(no key) but latch appears to be intact. Side support straps are included. No hinges. $100 no shipping SALE PENDING 4. 72 Sub 2nd seat. Medium green base model. No foam damage and no broken springs. Several small tears. Also 2 small rear tears. Seat belts for 3 spots. 2 good arm rests. All brackets included except holddown clamps. $200 no shipping. 5. 72 Sub 3rd seat. Medium green base model. No foam damage and no broken springs. One small tear. Seat belts for 3 spots. One armrest has a crack near ashtray. All brackets included except holddown clamps. $200 no shipping. Buy both seats for $350. SALE COMPLETED - THANKS PETE Pictures on Tuesday.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow Last edited by Bob Moore; 09-25-2005 at 08:06 PM. |
Nothing clever
how close is tacoma to seattle?
I will be in seattle next month shipping production equipment back and forth, and I am interested in those seats. Can you please send me some pictures. Thanks
Got "the Midas Touch!" |
Tacma is about 35 miles south of Seattle on I-5. Will be unavailable from Oct 13 thru November 10.
Pics later today.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Check out GMTrucks.org
I'm interested in both seats pending pictures.
Pictures as promised
Door panels ![]() ![]() ![]() Tail gate ![]() ![]()
Picture of seat
Other seat
Now with pictures
ttt
Seats - sale pending
![]() Join Date: Apr 2005
Bob, If the shipping for the tail gate is not to crazy I will buy it. My zipcode is 32571. May also want to check greyhound. Do you have the upper one also?
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Seats are sold. Thanks Pete.
Bob,
I was wondering if you can send me some more pics of the tailgate (robhartley@aol.com)? Also, if Greyhound doesn't work, UPS might not be to bad for the shipping. Thanks, Rob
