Old 09-20-2005, 09:32 AM   #1
76bonanza
76bonanza's Avatar
deisling question
I have had this truck for about 2 weeks and the last two days it has started on ocasion deisieling after I turn key off not real bad but enuf. Question I replaced the throtle return springs with lighter ones they seem to pull it back all the way and after it does it I check and the throttle is on the stop. Could it be when it is running it is not closing all the way sometimes then when it stops it does close? What are some other cuases of the run on? Bad gas?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-20-2005, 10:04 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The two main reasons for dieseling are excessive carbon build up in the combustion chamber and timing.
sneakysnake is offline   Reply With Quote
Old 09-20-2005, 10:08 AM   #3
76bonanza
76bonanza's Avatar
Timing to high? Or to low? I dont think it is build up the motor only has about about 1000 miles on rebuild block and heads. It is wierd it only started about 2 days ago but it has been hot also. And almost imediatley after I changed the springs.
1968 c10
lowered 3" 4"
Old 09-20-2005, 10:48 AM   #4
sneakysnake
Usually it needs to be advanced,Put a light on it. I dont know why a return spring would cause it to run on but you might try putting the old spring back on and see if it makes a difference, cant hurt.LOL
Old 09-20-2005, 10:56 AM   #5
76bonanza
76bonanza's Avatar
That is what I though but it ran fine for a week never did it, but the springs were really stiff put on some really soft springs to soft in my opion then it started and it does not do it ever time and not very bad. only thing I can think of is it my not be letting the butterfly close all the way? About what should the timing be I know that is an open ended question. Also I am almost sure the advance is on intake vaccum so it should be more advanced at idle?
1968 c10
lowered 3" 4"
Old 09-20-2005, 01:52 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A soft/weak spring could cause run on...but not likely.
Things to check;
timing being too far advanced
too low a grade of fuel
idle set too high
carboned up combustion chaimbers
valves not closing all the way
Poor work with sharp edges in the combustion chainber
Old 09-20-2005, 02:19 PM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I am not sure what difference timing makes. When you turn off the key, the ignition should be off and I don't think the motor can tell where timing was with no fire.
These trucks are notorious for dieseling...BB & SB. The "anti-dieseling" solenoids worked well, because they let the butterflies close all the way, so there was no more air & fuel entering the intake.
Run the idle as low as possible and make sure the return spring is strong enough to pull the butterflies all the way down.
If all else fails...turn the engine off "in gear"...just don't forget to put it in park or gear when it stops.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 09-20-2005, 10:11 PM   #8
76bonanza
76bonanza's Avatar
Timing is set to about 12-13 at idle with vaccum plugged
1968 c10
lowered 3" 4"
Old 09-20-2005, 10:22 PM   #9
Longhorn Man
Tried backing it back down to 8 or so? If it is a stock engine, that's what it's supposed to have.
Old 09-20-2005, 10:29 PM   #10
76bonanza
76bonanza's Avatar
It is not stock at all 355 roller rockers comp cam dyno about 330 hp 389 lbs build by hatfield racing in joplin mo not super bad but a little hot.
1968 c10
lowered 3" 4"
Old 09-20-2005, 10:29 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Turn it off while still in gear.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-20-2005, 10:49 PM   #12
Alan Potter
Idle is too fast
'12 Silverado Crew Cab 4x4
'05 Silverado SWB
'67 Chevrolet CST 2wd
'49 Willys Jeepster
Alan Potter is offline   Reply With Quote
Old 09-21-2005, 12:23 AM   #13
masterbeavis
Having issues
masterbeavis's Avatar
Turning truck off while in gear still works, but how safe can that be? Especially if you forget to put it into park? All it takes is one time to forget. I vote for fix the problem, not learn to live with it.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-21-2005, 10:33 AM   #14
71400lb
71400lb
I had the same problem...turned out to be a combination of the idle too high and 87 octane gas...I've since switched to 93 octane and lowered the idle, and it hasn't diesled since March of this years!
71400LB
1971 Cheyenne 3/4 Ton Long Bed
400 SBC/400 Turbo
2wd
71400lb is offline   Reply With Quote
Old 09-21-2005, 04:04 PM   #15
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
back your timing down to 4 deg base timing
and pickmup you should read some hot rod mags about how timing does effect
shutting and overheating problem with timming
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-21-2005, 04:58 PM   #16
acloco
....and check the distributor to make sure the mechanical advance is not stuck/sticking/worn out..........
acloco is offline   Reply With Quote
Old 09-21-2005, 05:05 PM   #17
fastwillie 696969
~Rest In Peace~
http://www.streetrodstuff.com/Articl...ion/Page_2.php
Old 09-21-2005, 05:22 PM   #18
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Interesting Info
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-21-2005, 05:55 PM   #19
jamal
jamal's Avatar
The valves get too hot and light the mixture instead of spark, like glowpugs in a diesel, hence the name dieseling. Too lean, timing too far advanced, or high compression with low quality fuel. Try running better gas, but timing should do the trick.
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
