Old 09-20-2005, 10:10 AM   #1
Don Brace
Active Member
Convert coil spring rear end to leaf spring
What do I need to do to convert an eight bolt coil spring rear end to an eight bolt leaf spring rear end? I have the coil spring rear end and another frame that has the leaf spring on it. Where do I get the parts? Is anyone interested in swapping a rolling all coil drum brake chassis for a leaf spring rear end. I would only need the leaf spring drum to drum rear end and ubolt set-up.Thanks
Don in MN
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 09-20-2005, 01:54 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
My question is why would you want to do that. The coil is better in just about evey way imaginable.
I'm actually thinking of making my longhorn a 1/2 ton, and if i do, it'll get coils... no way around it.
With that being said, what parts would you need if you have a frame with leaf springs on it already? other than new bolts, all the parts would be right there.
And this 8 bolt rear...what rear is this? is this a c/10 or a c/20?
Old 09-20-2005, 02:08 PM   #3
Americanrider
I think he means a 8 lug rear. Coil rears handle funky with a heavy load like a camper. Give me leafs anyday.
Americanrider is offline   Reply With Quote
Old 09-20-2005, 02:16 PM   #4
Don Brace
Active Member
8 Bolt rear end.
I have a Longhorn that set up for a leaf spring rear end but the rear end is missing. All it has is the leafs mounted to the frame. Does the leaf spring R E have mounting plates that the leafs mount on? I think I need the brackets that the U bolts go through. Is there anything that needs to be attached to the R E such as spring mounts? Yes I am looking for an eight lug rear end.
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 09-20-2005, 05:47 PM   #5
70short/step
70short/step's Avatar
cut the pads off your rear and buy leaf spring pads for the leafs and weld them on. Also you will need to weld on mounts for the shocks.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 09-20-2005, 05:51 PM   #6
Longhorn Man
ok, ignore my responce... not many ppl looking for haulers on here.
Old 09-20-2005, 05:53 PM   #7
67chevemall
67chevemall's Avatar
I wouldn't change it either.$0.02
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
