Old 09-20-2005, 11:56 AM   #1
hotrodhomi
hotrodhomi's Avatar
steering slop question
I have slop in my steering wheel. Not loose steering side to side when you turn the wheel but it acts like a loose steering wheel. I can move the wheel around by lifting up on it. Can something be loose or is it just worn out. The nut that hold on the wheel is tight. What can I do?
hotrodhomi is offline   Reply With Quote
Old 09-20-2005, 11:59 AM   #2
Russell
Professional Grade
Russell's Avatar
If you have a tilt column, the 4 little torx bolts at the base of the tilting mechanism need to be tightened. Just take the column apart (not very tough, don't worry about it) and loctite those 4 bolts in with permenant loctite.
This is a very common problem with these truck's tilt columns Usually the primary cause is you using it as a handle to get in (I know I do all the time!)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-20-2005, 12:57 PM   #3
hotrodhomi
hotrodhomi's Avatar
I have tilt. How deep into the column is it. I don't pull my self into the truck with the steering wheel but it was a little loose before I bought it. I could see that happening on a lifted truck but mine is lowerd. Anyway, thanks for the advice. I take it apart tonight if I get off from work in time.
Old 09-20-2005, 02:27 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
http://www.chevyasylum.com/column/tiltcol.html
Some instructions.
I need to do this. I replaced my turn signal lever and switch in December, but the column was tight. By February it was loose, and now I get to take everything apart again.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-20-2005, 04:04 PM   #5
hobbz
hobbz's Avatar
man, i need to do this too, thanks for posting the how-to
Hobbz-Garage
1987 Short Step 350/350
hobbz is offline   Reply With Quote
Old 09-20-2005, 04:28 PM   #6
SmittySmith
'82 GMC Sierra Classic
SmittySmith's Avatar
Well, as you can see by the instructions it's fairly deep... I wish I had had the instructions before I did mine.. but got through it OK. You will want to do the fix, because the problem will not go away, only get worse. I would reccomend you start on a Saturday morning or anytime that you will have some time, you don't want to start it thinking its only a 30 minute job... most aren't! SS.
SmittySmith is offline   Reply With Quote
Old 09-20-2005, 04:33 PM   #7
Slonaker
Slonaker's Avatar
I an't change my oil in 30 minutes. Something always goes wrong when I work on this truck. It is guaranteed...
Slonaker
Stock '01 Silverado
Old 09-21-2005, 10:11 AM   #8
hotrodhomi
hotrodhomi's Avatar
This, unfortunately, was not the problem. I have a bad bearing deep inside, near the shifter knob. I’m not sure how to fix it. Would it be easier to just replace the whole column? I’m pretty sure I would need to remove it anyway to replace the bearings.
Old 09-22-2005, 01:22 AM   #9
hotrodhomi
hotrodhomi's Avatar
no response huh? I guess I'll be yanking it out.
Old 09-22-2005, 02:03 AM   #10
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I believe it's possible to get to the bearings without taking out the steering column. You'll need a few special tools to disassemble the column. The truck shop manual does have the step-by-step details. Do you have access to one? It's probably quicker (and easier) to replace the whole unit.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 09-22-2005, 02:12 PM   #11
hotrodhomi
hotrodhomi's Avatar
Well I got it out. But i'm not sure the extra one I have will work. What do I need to do the swap these, if anything? In the top pic the bottom one and in the bottom pic the left one is what come out of my truck.
Old 09-22-2005, 02:26 PM   #12
Jonboy
Slots go on anything!
If you have the lower shaft to the new to your truck column, it should bolt up. You may need to swap the wiring plug between columns if it doesn't plug right up.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-22-2005, 02:36 PM   #13
hotrodhomi
hotrodhomi's Avatar
so I if I go and get the shaft from the rag joint up it will work?
Old 09-22-2005, 04:43 PM   #14
hotrodhomi
hotrodhomi's Avatar
What year uses the spline style like the one on the left?
Old 09-23-2005, 12:44 PM   #15
hotrodhomi
hotrodhomi's Avatar
I think it was the early style. It might be a '73. I found a guy that will rebuild my old one for $250 it that reasonable?
Old 09-23-2005, 02:42 PM   #16
SSC's76
No No
SSC's76's Avatar
$250 seems a little high since it's alreay removed but if that includes all new parts (turn signal cam assembly, IGN switch, Key ect) go for it. I'm not sure on the spline deal, my 76 is the non splined type.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 09-23-2005, 03:10 PM   #17
Jonboy
$250 is not terribly unreasonable around here, I don't think.
If you go get the shaft from the rag joint up, it should work.
Old 09-23-2005, 05:01 PM   #18
hotrodhomi
hotrodhomi's Avatar
I think I found a shaft. The guy wants $40. I'm waiting for him to get off work so I can get it.
Old 09-24-2005, 03:11 PM   #19
hotrodhomi
hotrodhomi's Avatar
I got the shaft and the column is almost in. The harnest has all the same wires but doesn't fit. Does every thing line up in the correct order or am I looking at a fire if I force it in there. The new column is a '73 and the truck harness is a '81.
Old 09-24-2005, 04:58 PM   #20
hotrodhomi
hotrodhomi's Avatar
I got the turn signals to work. The singal wires and the horn are the only wires in the long skinny plug, right? What are the other plugs for? Nuetral safety switch and ?? My truck is not starting. what plug should I be looking at? Please help.
Old 09-25-2005, 12:01 AM   #21
DroppedZ84
DroppedZ84's Avatar
$250?! WOW! That's highway robbery!
I had my tilt column rebuilt locally for $100.
DroppedZ84 is offline   Reply With Quote
Old 09-25-2005, 12:03 AM   #22
hotrodhomi
hotrodhomi's Avatar
The truck is back on the road!
Old 09-26-2005, 11:54 AM   #23
piecesparts
Parts and more parts
piecesparts's Avatar
Something that is not in the instructions on the column disassembly; there is a tool for pulling the pins from the tilt housing, which will allow for reaching ALL four of the torx bolts. Snap-On sells them and they are kinda wierd in design. There is a small bolt that screws into the pin and then a cup assembly sits over it to allow for a nut to be tightened down pulling the pin. If you get a small bolt threaded into the pin and get a small slide hammer, you can do the same thing. There is a pin on each side (pivot point for the tilt) and once they are out of the way the upper steering column unit swings out of the way (sort of).
piecesparts is offline   Reply With Quote
Old 09-26-2005, 12:21 PM   #24
hotrodhomi
hotrodhomi's Avatar
My column was diffrent inside anyway. The one in the "how-to" looks much newer.
