Old 09-20-2005, 02:36 PM   #1
FormerMember
Rear 5 lug rotors and other parts...
Ok, so I have my calipers, which should work really well. I can fab the brackets.
What rotors do you guys suggest for my rear disk converstion?
I thought about a 95 Caprice. SHould be a ten bolt rear and 5 on 5" lug pattern.
I briefly thought about switching to a 5 on 4.75" bolt pattern to run Vette stuff...
FormerMember is offline   Reply With Quote
Old 09-20-2005, 07:44 PM   #2
powell72
powell72's Avatar
I've heard about using a '77 Lincoln Continental rear rotor. They are a 5 on 5 bolt pattern. Anybody else?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-20-2005, 08:11 PM   #3
Bob Moore
The 77? - 78 - 79 Cadd SeVille (rear wheel drive) had 5 on 5" rotors. I believe the FWD SeVilles went to 4&3/4" .
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 09-21-2005, 08:59 PM   #4
masterbeavis
Having issues
masterbeavis's Avatar
thought big fords were 5 on 4-7/8?
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-21-2005, 09:09 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i wont use the linc rotors they have attend to get real hot and warp easy maybe a mustang rear rotors
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-22-2005, 01:44 AM   #6
396 SS
396 SS's Avatar
The Caprice will fit . The Seville rotors cost less but require minor machining of the center hole to fit the truck axle. I am going to use the Seville rotor and a GM metric caliper on mine.
396 SS is offline   Reply With Quote
Old 09-22-2005, 10:00 AM   #7
383 Stroker
383 Stroker's Avatar
I have the Caprice/Impala rotors. They work good.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 09-26-2005, 02:23 PM   #8
FormerMember
So, what brackets for a GM metric caliper?
I want to use a rear caliper from a 95 Buick Regal sport. got them cheap from ebay!
Old 09-26-2005, 02:34 PM   #9
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
where do you get the conversion kit works with these?
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 09-26-2005, 02:42 PM   #10
FormerMember
Well, that's what I am building, but I don't want to spend the $400+
So I bought the calipers with ebrake from ebay for 40.00 for a pair, shipped with pads.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN%3AIT&rd=1
they're 4" from bolt hole to bolt hole.
I also have a set of the old El Dorado rear calipers, which are 5.5" bolt hole to bolt hole.
Going to a boneyard for the rest of the ebrake linkage.
Rotors are 39.00 each from Vato Zone. 1995 Caprice with rear disk.
Need a caliper bracket, thinking about a Lou Feger weld on caliper bracket:
http://www.loufegersracing.com/weldon.html
They (Vato Zone) aslo have the Crapice caliper bracket???
http://www.autozone.com/servlet/UiBr...%7ENONE%7C%7EW
Just wondering if there's a bolt on bracket that's available??? Anyone know if the stock Vato Zone Dorman bracket works?
Old 09-26-2005, 03:05 PM   #11
724wdcopper
graphic designer
724wdcopper's Avatar
check with speedway motors. they have disc brake kits and parts, mainly for the streetrod guys, but i'm sure your money is just as green
i think it's speedwaymotors.com
724wdcopper is offline   Reply With Quote
Old 09-26-2005, 03:08 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
There is a front disc bolt on bracket but I can't find my link.I never looked to see if they do a rear.Maybe a search would turn one up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-26-2005, 06:18 PM   #13
Inthuwind
Straight jacket required
Inthuwind's Avatar
Would this Caprice/Impala conversion work on a '72 12 bolt rear axle??
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 09-26-2005, 06:22 PM   #14
FormerMember
No idea... I am doing research ATM.
I bet that it would.
Old 10-04-2005, 05:21 PM   #15
Inthuwind
Inthuwind's Avatar
Ttt
Old 10-05-2005, 05:34 PM   #16
383 Stroker
Inthuwind, here are the pictures of the backing plate you wanted.
Old 10-05-2005, 05:39 PM   #17
FormerMember
What caliper is that?
I am grabbing a complete caprice rear end for the disks.
Should be a bolt on fit.
Old 10-05-2005, 06:27 PM   #18
383 Stroker
Impala SS/Caprice 9C1 caliper.
Old 10-05-2005, 08:43 PM   #19
72CSTC5
72CSTC5's Avatar
Okay, 383Stroker, let me get this right. Your complete rear end disc brake setup is off of 95 caprice?
72CSTC5 is offline   Reply With Quote
Old 10-05-2005, 08:51 PM   #20
Inthuwind
Inthuwind's Avatar
It is--he made his own brackets though---
Old 10-05-2005, 11:06 PM   #21
72CSTC5
72CSTC5's Avatar
Hey, inthuwind, thanks, the post was getting kind of confusing. Did he give you the specs on the bracket? I would be interested in the specs or buying a pair from him.
Old 10-06-2005, 07:48 AM   #22
383 Stroker
It's the same caliper and rotor that comes on a mid 90's Impala SS. I ordered the parts new from GM.
Old 10-06-2005, 07:52 AM   #23
FormerMember
Looks like a stock bracket (with 2 bolts) bolted to a fabbed bracket that bolts to the axle flange?
Ebrake?
Old 10-06-2005, 08:26 AM   #24
383 Stroker
Ebrake?
I made the backing plate that the caliper bracket bolts to. Here is another picture of it. No ebrake with this setup. The ebrake is made into the stock backing plate.
Old 10-06-2005, 08:34 AM   #25
Joe67
67 is sold
Nice clean setup
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
