Old 09-20-2005, 09:37 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
Exclamation HELP!! low RPMs at Idle after a battery swap.
I had a battery leaking on me. I have swapped it out for another and now when I crank up I Idle so low that it actually cut out on me once. This has never happened to me before. Its worth noting that I discovered the battery leaking when I was changing the Washer fluid Tank on my truck.
It is an 02 Yukon with a 5.3L V8
Any help appreciated
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 09-20-2005, 10:25 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
it basically has to go through a relearn process. hold the idle at about 1500 then slowly let it off until it runs by itself
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-20-2005, 10:27 PM   #3
full foot notch
yeah, pretty much a relearn process, the quick way i learned was to cycle it thru D and R every few seconds with the idle hovering around 800, and prolly after 3-4 tries it would learn enough to allow it to drive around the block, in which it would still learn while driving
full foot notch is offline   Reply With Quote
Old 09-20-2005, 10:31 PM   #4
phlegm
phlegm's Avatar
whew.... thanks guys, I thought that was the case but after driving around the block and it stalled, I got nervous. I will go do that now.....
MODS, Im removing the redirects now.... thanks
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 11-22-2005, 08:20 PM   #5
Hart_Rod
Hart_Rod's Avatar
Re: HELP!! low RPMs at Idle after a battery swap.
Would you have to do this procedure after installing a Hypertech tuning?
Thanks,
Rob
Hart_Rod is offline   Reply With Quote
