Old 09-20-2005, 10:12 PM   #1
76bonanza
76bonanza's Avatar
timing question
My new truck is set at about 12-13 intial timing seems high to me run and starts great. It is midly hot 350 roller rockers and such about 9-1 compression I am guessing about 330 hp and 387 lbs not sure if any of that helps?
thanks
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-20-2005, 10:41 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
As long as it runs good and doesn't ping.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-20-2005, 11:35 PM   #3
68haywagon
I'm watching you!
Pretty precise guess
Fred T
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 09-21-2005, 07:55 AM   #4
76bonanza
76bonanza's Avatar
well it was desktop dynoed so it is an educated guess
1968 c10
lowered 3" 4"
Old 09-21-2005, 08:15 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
I have about the same set-up. I run mine at 16* initial with the vacuum coming from timed instead of ported. & I use 87 octane. I know, I know, it is on the ragged edge of detonation but the mileage is cool & I drive it sensible
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-21-2005, 09:24 AM   #6
76bonanza
76bonanza's Avatar
when you say timed you mean intake vaccum or contstant vaccumm?
1968 c10
lowered 3" 4"
Old 09-21-2005, 09:32 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
by "timed" I mean it is dead until the throttle is opened. "ported" is straight from the manifold & has the same vacuum as the engine.
Old 09-22-2005, 12:31 AM   #8
jhow66
jhow66's Avatar
Have't you got that backward?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-22-2005, 07:23 AM   #9
68C15
blood type; Retumbo
68C15's Avatar
I could be wrong. but I always thought since it waits until the TIME the throttle is opened it was correct. and since a manifold is simply a set of PORTS this was fiting.
Old 09-22-2005, 03:23 PM   #10
jhow66
jhow66's Avatar
Ported -any port that has a opening above throttle blades.
manifold (fulltime)- any port on manifold or below throttle blades.
Old 09-22-2005, 10:18 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
OK, so I'm wrong. not the first time & probably wont be the last.
what was the original question? oh yeah, the 12-13* initial. its fine, some engines qill take more than others. it has to do with the cylinder pressure. some cams will bleed off at lower speeds. also the combustion chamber plays a roll as for how the flame front travels.
in short, if it works then all is fine.
PS. is it possible the balancer ring has moved?
