Old 09-21-2005, 08:47 AM   #1
Buckman
Question Rear flip kit?
I ask earlier how is the best way to lower a 71 gmc with leaf springs and Stllookn said something about a rear flip kit. What is a rear flip kit? And where can you get it?
Buckman is offline   Reply With Quote
Old 09-21-2005, 10:59 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
DJM (through Godfathers customs) has the the least expensive kit the last time I checked. The flip kit should be about $70. It will give you all the brackets and mounts to move your rear axle from under the springs to on top of the springs. This will lower the rear of your truck about 5 inches. This is "usually" a very straight forward project. Now knowing that those axle mount "u-bolts" have probably not had a wrench on them since it was built. You may need a can of "Bustem" and some heat to get them off. I have broken sockets trying to loosen those nuts. No matter what you do to your suspension it is going to take "Bustem" and a little sweat...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-21-2005, 11:19 AM   #3
Buckman
Question leaf springs
Thanks Stllookn, do you have a address of godfathers custom, I could not fine it. Also 5" sounds like a lot, I have 18" wheels on it will this cause a problem?
Old 09-21-2005, 02:07 PM   #4
stllookn
stllookn's Avatar
http://www.godfathercustoms.com/
Should be plenty of room. Take a tape measure and check out your wheel wells before you proceed just to make sure.
Old 09-21-2005, 05:33 PM   #5
powell72
powell72's Avatar
Early Classic makes 4'' drop leaves and a 1.5'' drop shackle for leaf spring trucks.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-21-2005, 07:09 PM   #6
tomatocity
tomatocity's Avatar
But not for $70. I want to do the same 5" drop and have considered the plus' and minus'. The flip kit seems to be the most economical but you still have the 30+ year old springs. The drop springs would be nice but the additional $$$ could be used for something else. I plan on using the flip kit and taking the leaf springs and shackles apart cleaning and lubing them them and reinistalling them. I believe you can get teflon strips to put in between the leaf but I don't know if it is necessary. I plan on using a 3M pad and polishing the contact areas of each leaf. This should allow the the leafs to move easier. I am sure the shackles are not loose so I will remove, clean, lube, paint and reinstall them. I am not sure what lube to use for the bushings and springs. I don't want to use something that will attract and hold dirt.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 09-21-2005, 07:38 PM   #7
69 longhorn
I flipped my longhorn.....she runs stock leafs, with the flat overload & 3 tossed off the bottom of the stack. The 12 bolt diff came from a 75 C-10 donor, & the pads needed to be replaced. I went direct connection (chrysler) pads, set the pinion angle & welded them on.After the drop, the spring hangers were moved down on the frame just a tad(1 1/4"), to bring things good front to rear. The front is a 1 coil cut drop (about 3"),'75 1/2 ton spindles & the body is dropped 1 1/2"(lots of work, but nothing makes sparks on the pavement ) best of luck, L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 09-21-2005, 07:50 PM   #8
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Not that I'm an expert at doing this, but we did it alittle different.
1. We took the rear end and springs out and apart.
2. Took our 30 year old springs to the spring shop to get reconditioned.
3. Grind off old perches on bottom on axel tube.
4. Bought Moroso Spring Perches $16 at local speed shop.
5. And will be welding them on after we get the ride height set.
6. Bought new U-Bolts (Don't want truck hanging from 30 year old bolts)
7. Bought new shackles, originals were rusted up.
8. Cut the frame and welded in 6in dia. steel pipe for a c-notch
We havent figured out lower shock mounts but will be most likely building them ourselves.
We have pictures if anyone wants to see them.
Dry graphite might work instead of lube for the axel bolts.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 09-21-2005, 10:58 PM   #9
modifiedGMC
Too bad you are not closer. I got a 1989 drum rear end that already has the mounts flipped, the springs and shackles that I need to get rid of. I think the shackles are the lowered type but not sure.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 09-21-2005, 11:08 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can buy simple axle saddles at any trailer supply house. Here, we have stores called Tractor Supply that sell them damn cheap. All they are is a saddle for 3 inch tube.
Old 09-21-2005, 11:18 PM   #11
70short/step
70short/step's Avatar
Does it matter what the spring width is?
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 09-22-2005, 12:27 AM   #12
corn
I put a 73-87 flip on mine. It was pretty straight forward but I did have to trim the axle mounts just a little...corn
corn is offline   Reply With Quote
