Old 09-21-2005, 08:45 PM   #1
76bonanza
76bonanza's Avatar
electric choke install
Installing electric choke on holly carb in the morning. Read directions is it really that easy if anyone has any tips.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-21-2005, 09:15 PM   #2
70 shorty
Where's my beer?
70 shorty's Avatar
do you mean you're converting to electric from a manaul choke, or you just need to hook up a wire? If you're just hooking up the electric, if there's not a wire there that's got power to it with the key on then run a wire from the ignition unfused port on the fusebox. Then adjust the choke so it snaps shut when you put the gas pedal to the floor, and then it should slowly open once you start the truck until it's straight up an down when the truck is warm. If you're adding choke, I think it's pretty striaghtforward also. Anynone else feel free to jump in and correct me if I'm wrong on anything.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 09-21-2005, 09:37 PM   #3
76bonanza
76bonanza's Avatar
converting from manual
1968 c10
lowered 3" 4"
Old 09-22-2005, 09:24 AM   #4
guyryan100
guyryan100's Avatar
I piggy backed the + wire off the wire that connects the HEI to the fuse box. So the red wire basically run from the side of the carb to the dist.
guyryan100 is offline   Reply With Quote
Old 09-22-2005, 11:15 AM   #5
67chevemall
67chevemall's Avatar
I have to do this too, I'm going from Holley manual to Edelbrock electric.
Is this the way to go then?
Whould be a short wire which is good.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
