09-22-2005, 08:19 AM | #1 |
Spare parts? What are they?
Hello gang,
I had to stop my my engine redo 3 years ago because of my wonderful newborn. He's getting trained on shop tools now so it won't be long before he's under there turning wrenches with me (He, he - can't wait). But seriously, I had a guy helping me do the engine restoration. When he gave the engine back to me for installation, there was a box of parts, to put on the engine once it was re-installed in the truck. Well, since I have most everything back on, there are a few pieces I can not identify. Lookie here: what are rod "A" and bracket "B" used for? Also, this is not an original coolant overflow bottle. Can anyone I.D. it from another car? Thanks for your help
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
09-22-2005, 09:15 AM | #2 | |
User #12137
"a" kinda looks like the rod that goes from the master cyd booster to the cab |
09-22-2005, 09:26 AM | #3 |
Resident Curmudgeon
I can say for certainty that A is the rod that goes from upper alt bracket to head. See below
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
09-22-2005, 10:39 AM | #4 |
Questionable
A looks like the carb linkage bar for my inline 6.
The over flow bottle looks like the one in my '68.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-22-2005, 10:48 AM | #5 |
Awesome, what about "B"
Thanks alot - Item "B" is a puzzler though - any thoughts where it goes?
09-22-2005, 10:51 AM | #6 |
"B" is for the rear support on the A/c compressor.
09-22-2005, 10:58 AM | #7 |
Wow, that was not in my parts book, thanks
Do you have a drawing or picture to describe its location? I do not see this in my parts books or assembly manuals for a BB A/C bracket.
I see that the SB 350 bracketry looks alot more complex than the BB, but I can't see how it hooks up.
09-22-2005, 11:08 AM | #8 |
I'll take a pic of mine be right back
09-22-2005, 11:14 AM | #9 |
rod a is a bedside to frame bracket. it holds the fender lip to the frame so it doesn't flew, i know because i had to weld one out of 3/8" round bar becasue i only had 1.
09-22-2005, 11:23 AM | #10 |
Here ya go.
Hope this helps. |
09-22-2005, 11:39 AM | #11 |
Questionable
Ok, I just looked at my carb linkage, it's definitely not what I suggested. I can take a pic of my washer bottle when i get home to compare. I have it out and on my floor right now.
09-22-2005, 01:28 PM | #12 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
09-22-2005, 01:31 PM | #13 | |
Resident Curmudgeon
72-only style brackets. 68-71 were slightly different
09-23-2005, 01:37 AM | #14 | |
09-24-2005, 07:52 PM | #15 | |
72 BB C30 Super LongHorn
DEMI: Excellent Images!!!!!
Good work DEMI!!!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
09-24-2005, 08:03 PM | #16 | |
The LuvShack Garage
I never seen one of them there set-ups before, that's different alright
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
09-24-2005, 08:07 PM | #17 |
The BB A/C setups are tricky to do right but patience is the key to assembling them!
Those lower brackets are difficult sometimes if you do it alone!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 09-25-2005 at 12:56 PM. |
09-25-2005, 09:29 AM | #18 |
that's it, thanks RPOZ11
Yes, I checked it out and you were absolutely right.
I am currently looking at putting the comperssor back on and I read that there are some difficulties? I'll be interested in any tips you can give, so I do not screw it up! Thanks in advance,
09-25-2005, 12:58 PM | #19 |
Hints?....
My best suggestion is to have an extra pair of hands around to help support and hold up the compressor as you install those lower manifold brackets! That compressor gets heavy after a while one handed!
