07-03-2002, 11:12 PM | #1 |
any tips on oil pan change?
Never done this before, but seeing as how my engine will be out anyway, I was wondering if anybody has any helpful tips on replacing the oil pan. Is it as straightforward as it seems? My old one has a hole in it Thanks.
68GMC in family since new Victoria, B.C. Canada |
07-03-2002, 11:43 PM | #2 |
72 Cheyenne
Make sure you get good seals, they like to leak. Good sealant and gaskets and you shouldn't have a problem
07-04-2002, 09:22 AM | #3 |
Like dion says, use plenty of sealant on both sides of gasket. Two diff. sizes on pans up front depending on year of pan. They usually give both sizes in gasket kit. Make sure you use the right one.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
07-04-2002, 09:49 AM | #4 |
I would use Fel-Pro's one peice oil pan gasket. I'm using one, and I LOVE It!!! Does not leak a drop!! hehe.
07-04-2002, 10:55 AM | #5 |
I SECOND THE ONE PIECE OIL PAN GASKET. THEY ARE GREAT.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
07-04-2002, 12:11 PM | #6 |
Thanks a lot you guys! I'll go with the one piece Fel-Pro.
07-04-2002, 12:22 PM | #7 |
faster, faster, faster
Just make sure to follow the directions for applying the sealant that come with the gasket. It is very important that you only use sealant where it says to, if you don't you will get a leak. And be acurate on the torqueing of the bolts too. Follow all the steps outlined in the directions, and you will never have a leak.
I'm going to Law School, wanna debate? It's good practice. |
07-04-2002, 12:34 PM | #8 |
Drain the oil first, hehe.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
07-04-2002, 12:58 PM | #9 |
Registered Cruiser
It's not uncommon for the flange on the pan to become distorted from being previously overtorqued. I always check for this. If it is streched in around the bolt holes you can flatten it out with a small hammer. Go easy with the gasket sealer or all of the excess will end up on your oil pump pickup screen. Even the best gaskets shrink a little, so check the pan bolts after a couple weeks to make sure they're still snug. Hope this helps.
I intend to live forever. So far, so good. |
07-05-2002, 06:56 PM | #10 |
Between Trucks...
i put oilpan studs in place of bolts...
they kick a$$...
Beat it to fit, Paint it to match... |
07-05-2002, 08:49 PM | #11 |
huh?
I have also used the one piece felpro gasket. I love it, and if you ever have to take your pan off, you can reuse it! It's a very nice setup, comes with new bolts and everything.
TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
07-05-2002, 10:32 PM | #12 |
Gee, TJ, I wounder where you got your pan gasket from??
07-06-2002, 05:28 PM | #13 |
I agree, one piece rubber gasket is the only way to go. Also, make sure you get the right year oil pan. Not all sbc oilpans have the same front and rear seal clearances. Good luck and keep on truckin'!
