need help with cruise control
i am currently selling my factory cruise control on ebay. i really need to know how and what i need to include when it sells. ive been telling people that i will include everything that is needed for the cruise to work, i just am not sure exactly what is. it is off a 69 burb
Member #1049
you would need to include the servo which you have pictured.. the turn signal/cruise lever on the steering column or the dial on the dash (not sure which version your year has).. the speedo cable from the servo to speedometer, the wiring hooked to the servo which routes to the fuse panel, the vacumn lines and tees.. the brake pedal vacumn release switch and the little bracket that it touches.. its on the brake pedal,, the firewall vacumn pod and little chain that hooks to the carb, the little bracket on the carb that the chain hooks to, plus all the little nuts and bolts,, Hopefully I havent missed anything.. Anyone else have any input?
do i need to pull the steering wheel off to get the turn signal out. i unplugged the wiring harness from inside. the other end of the plug had three little wires going up through the column and those wires were sticking out of the broken turn signal. the auction is up in 20 hours.
Born a Chevy Man
You do have to pull the wheel. The turn signal is held in by a screw behind the wheel.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
i probably have to a special tool dont i?
#6 | |
Born a Chevy Man
