09-25-2005, 07:56 PM | #1 |
PROJECT 7DEUCE
72 Inside door release handle thingie
I know the the window regulator has a longer shaft on 72 doors but are the door handle spline thingies also longer???? I need one for the passenger side door if anyones got one.. T.I.A.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-25-2005, 08:26 PM | #2 |
Both are longer than 67-71
09-25-2005, 11:18 PM | #3 |
Frenchblue - I have found that Vans have the door remotes you are looking for with the longer shaft. If you have a yard nearby look for the newest van you can see (well into the 80's) to get one with a good spring and little wear. This is a tip to all of you with 72 doors and broken drivers side springs - very easy to find and cheap.
Keep on sharing the knowledge - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
09-26-2005, 05:59 AM | #4 |
That's good to know......I need the drivers side....
1997 GMC Sierra Ext 1965 Mustang |
