someday it will be done!
need some input on air setup
I've been thinking about different ways of mounting my pumps under the truck while still having them accessible.This is my first attempt,and as you can see they will be fairly easy to get at and remove.Not shown in the pics are the water trap that will be mounted in the box as well.That and the air intakes that will be plumbed out the back of the box and mounted somewhere nearby.My main concern with this whole thing is,am I going to have a ventilation problem here?I've drilled a ton of holes in two sides of the box but I'm not sure that is enough or if it's an issue.I'd apprieciate some advice from those who know more about this stuff
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
nothing?
Head Peon
![]() Join Date: Dec 1999
I guess give us some insite on why you are making the box...are you trying to hide them? protect them from theft or the elements? I think it's the first time I've seen somebody make a box to put everything in...nice box though
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
hmmmm it's a combination of all those things you mentioned Shev.I wanted the compressors both close together for easier,cleaner plumbing and easy access should I ever need to work on them.This way I just pop the latches and off comes the lid with the pumps attached.Like I said before though,my main concern now is whether these things need alot of outside air to assist with cooling?The intake will be outside the box.
Head Peon
I would say as long as they have plenty of ventilation there shouldn't be a problem...they are designed to live outside in the elements, you are spoiling them
Happy to be here
![]() Join Date: Mar 2000
It's certainly a good idea to cover those rascals since they are LOUD. I can't see the rest of the box, but it looks like you need more holes. Do you have any in the top? Remember heat rises and it needs to vent out the top when you are sitting still....
hehe yea I suppose you're right Shev I am spoiling them but in this case it's all about hiding them without destroying them
![]() good advise N2TRUX,I think I'll get the drill out again.
#8 | |
LAIDOUT
Never Done?
![]() Join Date: May 2000
I've heard one truck running an electric compressor, and yes I would describe it as annoying loud. But everybody has a different opinion on what qualifies as annoying. I'm gonna run an engine driven compressor and a couple decent size tanks. I was willing to do whatever it took to keep my truck from having that sound coming from beneath the bed.. but again, that's just my preference.
Happy to be here
The small thompson compressors aren't too bad. The ViAir 450 is a LOUD. We mounted mine at the rear of the truck and it's fine if your inside, but outside it's a noisy mofo...
