Old 04-15-2002, 07:16 AM   #1
Huck
Huck's Avatar
Question 79 4x4 ps gear box into 71 blazer?
Jamie 72 and I are working a deal on a PS gear box for my 71blazer. He found a 79 4x4 parts truck and the belief is that the PS gear box is the same. Anyone with any first hand experience here that can verify? Would 1/2 ton verses 3/4 ton make a difference?Thanks---Huck
72 Cheyenne, 350, 5spd, LWB, Super trim.
71 GMC JIMMY 4X4 --needs stuff-!
Huck is offline   Reply With Quote
Old 04-15-2002, 08:34 AM   #2
JJR
JJR's Avatar
Post
This is what Hollanders shows will work:
BLAZER/JIMMY (full size) 69-76 Power Steering; 4x4
CHEVROLET PICKUP TRUCK 69-76 Power Steering; 4x4
GMC PICKUP TRUCK 69-76 Power Steering; 4x4
SUBURBAN 69-76 Power Steering; 4x4
7825868 $545 obs
Less upper jacket, upper shaft, pitman arm, shifting mech. and wheel
1249 fits by including coupler.
It also shows these will work:
BLAZER/JIMMY (full size) 77-79 Power Steering; 4x4
CHEVROLET PICKUP TRUCK 77-79 Power Steering; 4x4
GMC PICKUP TRUCK 77-79 Power Steering; 4x4
SUBURBAN 77-79 Power Steering; 4x4
464160 '77-78 $585 obs
7832402 '79 $585 obs
Less upper jacket, upper shaft, pitman arm, shifting mech. and wheel.
959 fits by including coupler.
It looks like the 79 box will work if you get the coupler (I assume this is the rag joint).
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 04-15-2002, 10:39 AM   #3
MJN
MJN's Avatar
Post
The gear boxes are the same externally buthte gearing inside is different. It should bolt right up and it doesn't make a difference between 1/2 and 3/4. The rag joint may be different but they are easy to get.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-15-2002, 03:41 PM   #4
Huck
Huck's Avatar
Smile
Thanks guys for the feedback. Sounds like it will work out. Now on to the next interesting opportunity. Huck (:> )
