09-27-2005, 01:58 PM | #1 |
Z'ed Steering Question
I want to begin Z'ing my frame on my 66 C10. My question is what do you guys do for the steering on a Z'ed frame. Add a joint to the steering column shaft?
Thanks Shane |
09-27-2005, 04:15 PM | #2 |
Depends on how big your Z is. You will probably need 2 joints, maybe 3.
10-12-2005, 03:34 AM | #3 |
BK Built
you can also notch your UCA... if you get a piece of 2"OD tubing, say .125 wall thickness, cut the notch out, take a short piece of the tubing, cut it in half, and weld it in, youve got a notched UCA and arent losing any strength. thats what i did with mine, and ive seen 1 or 2 other done that way. keep in mind i did have 1 u-joint and the very top of the steering shaft where it comes through the firewall and connects to the steering column because i was running a firebird tilt column and they come through the firewall at a different angle.
10-12-2005, 09:29 PM | #4 |
Chevy truck addict
What is the uca?
10-12-2005, 09:40 PM | #5 |
Epoxy Primer Friendly
Upper Control Arm
10-13-2005, 02:26 AM | #6 |
Chevy truck addict
thank you camaro thunder for clearing that up for me. DCP could you post us a pic of what u did to your UCA Please.
10-13-2005, 02:37 AM | #7 |
BK Built
Im sorry but i cant post many pics these days. the only pics i have from the frame mods are limited, and i cant go out and get a pic for 3 reasons. 1 - no digital camera. 2 - i live 8 hrs from my panel. 3 - it got burnt to the ground... but ill get some more pics eventually, espeically when i get started on my other one here in a month or two
10-13-2005, 04:27 AM | #8 |
I cant wait for that NEW panel, I wasnt really a fan until I saw yours.
10-13-2005, 04:48 AM | #9 |
BK Built
thanks man, ive got some sick new plans i drew up, ill see if i can get the full pics scanned, but there are some tricks im going to pull out no one has seen on this new one... you all will hopefully be a fan of the new one!!!
