Old 09-28-2005, 07:45 AM   #1
Yamaha74
Found a truck
I found a 68 Chevy longbed yesterday that is for sale. This truck is a 1/2 ton, 2wd with a 307 motor and 350 turbo trans. Stainless steel dual exaust. Motor is pretty fresh. I haven't drove it yet but I heard it run yesterday. The body is in alright shape. The rockers and cab corners need replaced, which he already has but hadn't had time to put them on. Everything seems to work on it from the lights to the guages including a aftermarket tach. He is wanting $1,800 for it. I know I have seen some posting on this site about the window frames being rusted out and if that is the case they are pretty much unrepairable. I don't know how to tell. They don't look that bad, but I am in no way an expert. If I can get some pictures would you guys be able to tell?
Yamaha74 is offline   Reply With Quote
Old 09-28-2005, 09:03 AM   #2
shifty
Questionable
shifty's Avatar
Someone here should be able to.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-28-2005, 09:24 AM   #3
motocrosschump
send me pics to motocrosschump@cableone.net and copy this link into it and I will post it.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 09-28-2005, 09:37 AM   #4
72orangepumpkin
Father of a Chevy Boy!
72orangepumpkin's Avatar
I have seen trucks wih rust around the frames of the rear window and windshield, you might be able to tell by prying up the weatherstipping (if it doesn't have the chrome insert) around the windows and see what it looks like. Fortunately I caught the rust in mine early and was able to fix it, Sorry it's about the only thing I don't have pictures of.
Be cautious about known rust in the rockers and cab corners, as often times the cancer seems to go much further than the eye can initially see... ie. cab supports, inner rockers, A and B posts etc. All the parts are available, but you may have a bigger project than what meets the eye.
Hope it helps... -Chris
72 Chevy 4x4
Restoration in progress!
72orangepumpkin is offline   Reply With Quote
