Old 09-28-2005, 10:39 AM   #1
k72516
k72516's Avatar
Body Swapping Laws
I'm in Massachusetts, and it's a really anal state on lifting. I was thinking about getting a bigger truck (for example, there's a 1980 International dump truck for $1,500.00) and just swapping any decent truck body onto it.
I'm not worried about all the work it's going to take, I just wanted to know if it's even legal. I mean, guys swap out old rusty cabs all the time and don't have problems at the RMV... same idea, right?
Go Fast - Be Loud
k72516 is offline   Reply With Quote
Old 09-28-2005, 11:59 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I set a 2wd cab on a 4wd chassis. I used the cab title for my registration. I don't see where you'd have a problem.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-28-2005, 03:22 PM   #3
k72516
k72516's Avatar
Well, in Mass... they basically have a book that says "If you got this truck, then the bottom of your rocker has to be no more than this high off the ground." Bassically you're only allowed to lift like 2, maybe 3 inches. I figured if I did a body swap and tried to keep it registered/titled as a dump I would be able to get around the lift laws. Plus, it'd be bad ass having a 6.7L gas motor with a beefy 4WD dump chassis under it... Only problem I'm seeing is the VIN numbers getting screwed up and trying to convince inspectors and the RMV that it's a dump, not an old chevy.
Well, I guess no one else has any info. Thanks for the reply though, I'm just gonna call the RMV or police or whoever and get the official scoop... *getting ready for mondo fun pass the buck phone tag awesomeness* I'll post up what happens.
Go Fast - Be Loud
Old 09-28-2005, 03:23 PM   #4
k72516
k72516's Avatar
btw, *****in truck
Go Fast - Be Loud
Old 09-28-2005, 04:56 PM   #5
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
Same here.
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 09-28-2005, 07:27 PM   #6
a28doc
'87 V20 4x4
a28doc's Avatar
I think you have to keep the title to the cab which has the vin for registration but I not totally sure sounds like a kewl truck tho post pics if you do it
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 09-28-2005, 07:57 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
why not transfer the vin plate from the old cab to the new cab? irregardless of the cab it what's underneath that makes it what it is.
Old 09-29-2005, 11:24 AM   #8
k72516
k72516's Avatar
Hmm, I didn't know you could do that.
Go Fast - Be Loud
Old 09-29-2005, 03:22 PM   #9
GMC71k20
how high do you wanna go? i know of a person that got away with 11" of lift after meeting with a dot inspector and showed him it was done in a safe manner. i have no problems with my 8" and i have plenty of other friends with trucks this big
GMC71k20 is offline   Reply With Quote
Old 09-29-2005, 03:26 PM   #10
stan79chevy
stan79chevy's Avatar
is it legal to put a car body on a truck frame?
if you make all the mounts right it would be even safer than factory. a 70 chevelle wagon would look good on my frame, and fit the wife and kids with room to spare.
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 09-30-2005, 10:42 AM   #11
Most states require that you get a reconstruction title when changing bodies.Not that many don`t slip through with VIN-plate swapping.I know a Maryland State Troioper that set a`71 on a later 4wd frame and registered it as historic,not legit but he did it.In MD,if it`s over 10,000 GVW(1 ton),the height laws don`t apply.It`s all BS.The body-swap thing is such BS.If you own both vehicles and have titles for both,why can`t you do what you like as long as it`s within safety specs?You can change any other parts you want legally as long as it`s the same cab`n`chassis.
Hey,if humans can change their bodies/gender(Eew,visual,YUCK!!),than why not a truck????WTF
Old 10-01-2005, 07:07 PM   #12
TP from Cntl PA
TP from Cntl PA's Avatar
I am going to do the same thing on my next repower project...............Put a '67-'72 GMC Cab/front clip from a 3/4 ton on a 2-ton 4x4 truck frame for a ultimate trailer puller...............I figure as long as I adhere to the state inspection proceedure, and keep small rubber/rims on it I don't think I'll have much problem here in PA. Basically, I want to run a large Diesel with a large heavy transmission behind it and even a 1-ton frame wouldn't handle the weight with a trailer behind. Safer this way IMO.
Keep us posted as to what happens.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
