Master Blaster
Alright blazer Gods.........
I just picked up a set of 97 yukon cloth buckets and console
Slots go on anything!
Yep. I just drilled a couple extra holes, and used grade 8 mounting hardware. Find some thick fender washers to brace up teh floor around your new holes as well. I put 98 extended cab seats in my 77, and I have a 60/40 bench for the 78.
1974 Jimmy- 5.3/4L80e/NP241 |
Master Blaster
Jonboy, does your extended cab passenger seat slide towards the dash with the lever on the seat back? That is really what I was looking for, but got a good deal on these with the console and my drivers seat is power. Also did you use the frames and tracks from the newer seats? thanks jesse
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
N2TRUX made new mounts for his so he could use the existing mounting points for the new seat. BTW, the extended cabs made before '99 I believe (those without 4th door) will slide forward. That is what Ken (N2TRUX) used.
It was simular to what I did on mine to put the '90 seats in my '78. Links are basically in order of what I did... I made a template for it now so I can cut them out. http://www.captkaoscustoms.com/Jimmy/seatbracket1.jpg http://www.captkaoscustoms.com/Jimmy/seatbracket2.jpg http://www.captkaoscustoms.com/Jimmy/seatbracket3.jpg http://www.captkaoscustoms.com/Jimmy/seatbracket4.jpg http://www.captkaoscustoms.com/Jimmy/passtemplate.jpg http://www.captkaoscustoms.com/Jimmy/seatbracket5.jpg http://www.captkaoscustoms.com/Jimmy/seatbracket6.jpg http://www.captkaoscustoms.com/Jimmy/jimmybrkt.jpg
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 09-28-2005 at 06:27 PM. |
The drivers side in mine is power also. I don't remember if the passengers side flips forward or not. I chucked the rear seat in my 77 as it stuck way up above the top of the quarters. I used the newer seat tracks. I got mine cheap too, so I used what was there. I was kind of undecided between the split bench and the buckets, so I have both.
#6 | |
Happy to be here
![]() Join Date: Mar 2000
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-29-2005 at 11:02 PM. |
Master Blaster
Those look sweet!!! I cant wait to get mine in. looks like you just used the stock brackets from the newer seats.?.
#8 | |
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Happy to be here
You did good. Heck I was surprised I even remebered all that. Besides you did a much better job of making the brackets...
#10 | |
#11 | |
Happy to be here
